2019 Pionner 1000-5 Limp Mode Cold weather
Jleblanc2019
6
Alberta , Canada
Hey guys so anyone else have this issue, right now i cant use my unit in the cold seems like anything under 0 deg , engine light comes on and goes into limp mode barely drags its own weight back to shop, let it heat up and its good? any ideas ? Thanks
bigshoe
bigshoe
422
1,427
i wouldn't move my truck at 0 degrees without it warming up a bit lol. i would say the ecm wants the dct and engine to warm up a bit before it moves .
Has to warm up, engine and DCT are extremely dependent on correct oil pressures. Viscosity changes so much at low temps, DCT and engine will not get correct oil flow.
Just let it warm up to normal temps.
Reactions: Rick53
TripleB
TripleB
15,737
141,521
Caryville, Tennessee
Heat up as in outside temperature or machine heating up?
Reactions: Rick53
Jleblanc2019
6
Alberta , Canada
no it still goes into limp mode even after running outside for a long time idling, warming up to operating temperature
Reactions: TripleB
TripleB
TripleB
15,737
141,521
So it's the outside temperature effecting the machine and not the operating temperature? I'm just trying to clarify so someone may be able to help u with your problem.
Jleblanc2019
6
Alberta , Canada
Correct it’s the outside temperature when it gets below 0 deg Celsius outside machine goes into limp mode
Reactions: TripleB
bigshoe
bigshoe
422
1,427
So even when u let it idle and get it up to temp it still goes into limp mode?
Vikes79
Vikes79
SKOL!
11,794
114,311
South Dakota
  2. Talon X4 LV
I highly doubt temperature is the real culprit.
I run the wheels off mine in the winter plowing snow in -15F all the time without a heated shop. I might let it idle for 30s before getting to work. Ran 10w40 Gn4 all winter too.
I would start with cleaning out your fuel tank...could have water in it. Check your air box, maf, etc.
Reactions: Rick53 and TripleB
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
I agree its not the outside temp. Something is up with the machine.
Need more details about what improved the situation if anything.
Reactions: Rick53 and Vikes79
Vikes79
Vikes79
SKOL!
11,794
114,311
South Dakota
  2. Talon X4 LV
tjoreo
tjoreo
1,025
1,975
Southern Idaho
Wouldn't be water in the gas freezing? May need some heat or ethanol fuel? I had trouble with my 700 in the cold winter, but never any trouble with my 1000 last winter. I usually run non ethanol fuel but in the winter I add a little heat, which I'm sure defeats the purpose of the non ethanol fuel, but I was worried about the fuel freezing.
Reactions: Rick53
Sunrider
15
Arizona/Oregon
I had an issue opposite of yours. At the time my new 2016 Pioneer 1000 would go into limp mode during hot weather. The problem was a defective PGM FI Unit p/n 38770- HL4 - A13. Honda replaced the computer . That was around 500 miles , I’m at 9000 miles now and no more problems.
rickoshea
i ran mine all winter,stored in an unheated shop,sometimes as low as -35 c. without any issues and used 10-40 gn4.
Haldog77
Haldog77
NTC's Mafia Enforcer
40,065
347,553
Bossier City, Louisiana
I wonder if the seatbelt is bypassed. If so, maybe that is being being affected by the cold.
