2019 Talon 37,000 Mile Report
hondabob
1,320
5,252
Prescott Valley, AZ
Still runs like new. The sub trans started shifting better after around 15,000 miles. My 2020 Talon doesn't shift as good when cold but it only has a bit over 7,000 miles. I check the coolant level at every oil change and the battery terminals every 3,000 miles. Its important to check the suspension for play at the oil changes. I remove the skid plates for cleanup and inspect the coolant hoses, wire harness, drive shaft U-joints, and brake lines every other oil change. I still get the rear axle click on turns when cold but ok after a warmup period when the grease liquifies.
37000miles
Hometeam
Hometeam
1,045
4,414
Normal, IL
I really appreciate these high mileage write ups!! I was wondering what to look out for as I am buying a buddy's Talon R off him that has over 35k on it too! Your reviews help! More road miles on it than you have but still high miles!!! Thanks for taking the time!!
hondabob
1,320
5,252
Prescott Valley, AZ
Found a very small coolant leak. Had to remove the seats and back panel to get to the hoses. The push pins get dirty and hard to remove. I spray them with WD40 and they are like new again.
Collantleak
