P1000 2020-2021 Honda Pioneer 1000 Deluxe Front Bumper
dswv42
90
144
Charleston, WV
Brother, I wouldn’t get all worked up about that bumper situation from the factory. Like @HondaTech said, 3’s have always had that bumper and 5’s with the hoop since 16’ so little late to that party ;) But if it bothers you that much and your a stubborn like you said , just have them give u an LE bumper like most have and at there cost! Just like the factory skid plate, knowbody wants to be seen in a G string!:eek:
View attachment 212196 View attachment 212197
Trouble is, I don't really care for the looks of the LE bumper.
Reactions: Isaiah
Russ989
Russ989
22,642
147,257
I like it more than most personally, you have a lot of options out there, I’m sure you’ll find something.
F005800B A5AB 40B8 8613 DA0161170F2F
dswv42
90
144
Charleston, WV
I already have something in mind that's very similar to the so-called "deluxe" bumper, which I plan to make due with until the time comes for an upgrade. However, the bumper I want will have to be fabricated, which gives it the added advantage of being unique.
Reactions: Russ989
Russ989
Russ989
22,642
147,257
Sounds good, just keep the weight in mind.
Reactions: Isaiah
Russ989
Russ989
22,642
147,257
Weight is definitely a factor, and the tube-style bumper I have in mind is both lightweight and very strong.
Can’t wait to see it. This is my third build and I’ve been very mindful about adding weight, it’s hard to do everything we do and not add a lot of it but I try to cut it everywhere I can.
Reactions: Isaiah and BigOL3
322,802
Ya not sure why that much turmoil on the factory bumpers. Many swap them out to something different and there’s a lot of options. Obviously building is another good one. Like you I do like the accessory bumper, helps keep the fenders somewhat attached. And is lightweight.
BigOL3
BigOL3
2,997
8,920
My mindset has been the opposite about the weight on the front end. I have the TC bumper, about 85-90# and suspect there might be some case of the weight being a hindrance, but in reality I LIKE that extra weight on the front end. When climbing up rocky, steep hill, it helps to keep the front end down and the 4WD making contact to the ground.
Russ989
Russ989
22,642
147,257
That’s true, if go on a diet I could have one of those lol.
dswv42
90
144
Charleston, WV
I like the look of the Tough Country bumpers, but fear they might restrict airflow too much. And while the high winch mounting point is nice, it looks like it could put a lot of stress on the frame during a hard pull. Basically, the high winch mount point puts it too far out of alignment with the strongest point of the frame, causing stress, but I'm not sure how to correctly describe it..
Reactions: CumminsPusher
275,760
As my research continues, I just discovered that the 2020-2021 Honda Pioneer 1000-3 Deluxe does not have the Deluxe front bumper. It's a pretty raw deal too, because if I'm paying for a Deluxe, I expect Deluxe features. If I decide to buy one, it will definitely be an issue at the dealership, and I can be pretty stubborn too.
Here are the part numbers for each of the three OEM front bumpers available for the Honda Pioneer 1000. It took some digging because the model numbers are confusing and the diagrams are all the same, only the part numbers change.
Standard Front Bumper (62510-HL4-A50ZA)
Deluxe Front Bumper (62510-HL4-A00ZA)
Limited Front Bumper (62600-HL4-A00 --> 08P70-HL4-A00)
I'll be honest, that's the first time I noticed there was 3 different bumpers, but almost all the machines were 1000-5 Deluxe or LE.
Reactions: Isaiah and TripleB
BigOL3
BigOL3
2,997
8,920
Been no problem with the frame that I am aware of. Some had a problem with the TC tabs being warped, but NOT the frame of Pioneer. That is why I added the support to the tabs while I had mine off.
Reactions: TripleB and Isaiah
dswv42
90
144
Charleston, WV
Your welds look like mine.
  • Haha
Reactions: BigOL3 and Isaiah
dswv42
90
144
Charleston, WV
Roger that!
sounds like you don’t like much of anything! Just sayin
When it comes to a powersports industry filled with crooked dealers pushing machines that are little more than expensive plastic toys, you're right, I don't. Having recently lost a lot of money on a steaming pile of Kawasaki, I hope to avoid making the same mistake twice. Otherwise, you shouldn't judge a book by it's cover.
61,549
You say not to judge a book by it's cover, but you've literally had only complaints or cast aside other members' replies since you got here. All the while not even owning one of the machines you're trying to tell us how to fix?
Just buy one and enjoy it. From what I've seen you post about riding, you aren't going to be doing anything near what the group I ride with puts these through and they are the ones whose pictures you keep posting. For the 5-6 upper arm failures, frame failure, etc that you see there are 1000 other machines with zero issues. You're overthinking it bud.
dswv42
90
144
Charleston, WV
My focus is to find problems and consider potential solutions, which might seem overly negative to some. As for posts about how I might use the machine, I did mention that some WV trails can be brutal. Things change, and I like being prepared. While I may use it lightly at first, I have been known to do some pretty crazy stuff.
When it comes to posting on forums, I tend to be somewhat matter of fact, avoiding things which can quickly send a thread flying off the rails, and I don't do much chit chat either. Again, don't judge a book by it's cover.
Reactions: Isaiah
115,790
From the sounds of it, you already knew about the expensive plastics And crooked dealers and then you got a Kawi. If you were that smart, you wouldn’t have bought the “steaming Pile kawi” as you put it to begin with. So either you got played or you got cought pumping the neighbors dog and you’ve become a grouchy old cuss that tells the kid to stay off your lawn. If there too much money like you said, just go and buy a used one that someone else fixed all your Complaints already and be done with it. Or wait...you’d b**** about that too!
I don’t need to judge a book by its cover, you’ve already opened it for all to read.
dswv42
90
144
Charleston, WV
Spoken like a true keyboard warrior. At least I don't judge someone from a few forum posts, or feel the need to make my point using nasty accusations. If someone said that to my face, they would not walk away, game over. You know nothing about me, so I'm going to leave it at that. Otherwise, I didn't get played, it was my first, and last, belt drive machine.
