2020 Honda 700-4 Deluxe CKP Sensor location
broknairo
Working to troubleshoot no spark problem. Nominal battery voltage good, fuses good, main ignition relay good.
Not getting 12VDC to primary side of coil thus no spark when turning over engine. Still need to rule out the ignition switch and CKP sensor.
We have looked very hard to find the CKP sensor and haven't been able to locate it on the engine. Does anybody know where this is located?
Thank you very much.
Don
43,293
Don
It's built into the stator assembly, but it wouldn't keep you from getting power to the coil.
