P1000 2021 1k5 no 4wd
Bartnc37
16
Wi
Bought this machine brand new about 6 weeks ago after an unfortunate incident with my former polaris, RIP, and a very steep hill, have 50 ish mainly road miles on it.
Got a bit of snow here today, figured I would try out the plowing capabilities. I have 2wd, 2wd diff, and 4wd diff but no regular 4 wd. I can see and feel the cables moving on the front diff but when I shift into 4 wd the machine shows 2wd diff and the front end is definitely not pulling. Also the shifter doesn't feel like there's any tension on it when over on the reg 4wd side. Sorry for the long winded 1st post. I will take it to the dealer when I get closer to the first service, just wondering if I'm missing something simple or stupid.
Tons of great info on here, I can already feel my credit card burning looking at some of these rigs.
Russ989
Russ989
22,642
147,257
I’ll have to look at the service manual but I’m not sure how you can have 4wd diff lock but not regular 4wd. Interesting for sure.
208,730
This isn't an LE is it? Non Le's will have 2WD turf mode, 2WD locked, 4WD non locked and 4WD locked?
Reactions: Russ989
ToddACimer
ToddACimer
Pioneer 1005-2
3,685
15,587
Oshkosh, Wi
Did you try pulling ahead and turning the steering wheel, you may need to see a differential speed between the front and rear and left and right tires to engage 4x4 and 4x4 locked
208,730
tdhanses
tdhanses
1,044
3,553
Kansas
Would the rear diff cable adjustments being off create this, show 4x4 but not engage? Weird though you have diff lock, 4 wheel drive is really only 3. I have a hard time believing you have diff lock engaging.
kamikaze
kamikaze
74
160
Linden, NC
Check the shift cables in the box under rear floorboard for adjustment. Sometimes you have to drive about 20 ft to get the lights to show what is selected. Just had to adjust mine
61,002
Box under the rear only adjusts the turf/2WD lock engagement.
Reactions: Bartnc37
ToddACimer
ToddACimer
Pioneer 1005-2
3,685
15,587
Oshkosh, Wi
Agreed, I think it's unlikely you're getting 4x4 locked without 4x4. Mine doesn't always lock until both front tires rotate
Bartnc37
16
Wi
I just went and tried it again. The front definitely is locked up in the 4 wheel diff lock. In reg 4 wd the front end doesn't pull at all. It's a 2021 base model, it doesn't make sense to me how I can have only three of he 4 modes. But like I said in the 4wd position the shifter doesn't seem seem to have any tension on it, when i put it in reg 4wd it kicks into 2wd diff lock and the shifter can just flip between those settings.
Either way thanks for all the input
Bartnc37
16
Wi
Sorry, it flops, not flips
kamikaze
kamikaze
74
160
Linden, NC
Are you verifying this with it on a lift/off the ground? Or are you going off the display?
Reactions: Bartnc37
kamikaze
kamikaze
74
160
Linden, NC
Also check that the cables aren’t pinched anywhere
7B3E6AD8 510D 4F1C 908C AB04C6A16EB8
Reactions: Bartnc37
dilligaff82
157
315
New Hampshire
This. My display quit showing drive modes a long time ago, but the lever still does what it’s supposed to do.
Bartnc37
16
Wi
I followed all the cables and they look clear and free. I'm not jacking it up, but I'm driving uphill in 6+ inches of snow . It is very apparent which drive mode you are in.
Reactions: kamikaze
Bartnc37
16
Wi
I followed all the cables down and they seem fine but it almost has to be that adjustment. Thanks for the pic/link.
I'm probably gonna wait a few miles for the 1st service and let the dealer fix it. I paid for the warranty in a moment of weakness so screw it, they can fix it.
