2021 Honda pioneer 1000 maintenance schedule??
chicknbroth
chicknbroth
HSB, Idaho
Ok I get the 20 hr or 100 mile service.
my dealer says it will be billed at approximately 5.5 hrs of labor plus parts he told me to expect $650.00.
not having even seen what it looks like under and inside of the vehicle. The majority of the items are listed as “Check” or “inspect”. The question that I couldn’t get a clear answer on is what is exactly done on an inspection or check. My dealers first available date for service is 12/22. So I took it.
Do you all go by hours or miles. I could hit the 100 miles in three days. Then what? Will have more questions in the near future.
chicknbroth
chicknbroth
HSB, Idaho
here is a spreadsheat in pdf format of how i understand the maintenance schedule
Reactions: ChadD
tdhanses
tdhanses
1,044
3,553
Kansas
Personally I wouldn’t take it in if you are mechanical, just change the engine and dct oil and call it good. I always do visual checks and unless its starting hard no need to look at clearances.
You go by whatever comes first, it will vary for everyone.
208,728
I'm sure you realize that 12-22 is thirteen months away?
67,170
Agree,
Most dealers will most likely only do an oil change which is the Engine/DCT + both filters.
Some will check the air filter, if you are lucky.
Few will actually check alignment and other small things listed.
This should only run $2-300 bucks. (total cost)
Some dealers will do a valve inspection whether it needs it or not. The manual says "only if noisy". (most don't need this)
Some will even change the diff fluids (not required).
Or the Sub transmission oil (not required).
All this is extra $$$ and should be in the $5-600+ range.
If you can change the oil in your car/tractor/boat... Then you can do this.
The issue for most becomes TIME!
You can go by Miles or Hours. Book says whichever is first.
I guess it depends on how you run. 150-200 miles and still under 20 hours is fine.
After the initial oil change. I would stick to 1200 miles or 100 hours. (whichever is first.)
