P1000 2022 turf mode
rick79
I had my rear diff adjusted at dealer a few hundred miles ago. rear diff is not unlocking again! Adjustment on diff is at full adjustment and not even close. cable is fine. is there anything else to adjust?
Reactions: Lady01
ODAMO
ODAMO
1,177
3,206
P1000 Rear locker cable​
Not sure how to link a thread here but this thread may help you.
ODAMO
ODAMO
1,177
3,206
46EDB508 337A 445E 88E7 16B5467E4486
I ended up making a 3/8” spacer to add in to be able to adjust my 22. Been fine since.
Reactions: Hawk53
107,306
Welcome from tge putrid swamp run Michigan!
What year make and Model do u have?
ODAMO
ODAMO
1,177
3,206
We used to do this to the brakes 25 years ago.
Seems like the would of found a better design by now.
With a 10' long cable they need atleast twice the adjustment travel. Had the other end of the cable casing been threaded into its bracket there coulda been some adjustment there too. But they didnt....
ODAMO
ODAMO
1,177
3,206
LOL funny you say that cause its exactly what i was thinking, gonna try dealer one more time first since warranty is good till june
Let us know what they do and how it works out.
treeguy27
37
84
Mo
I have a '22 as well and had to adjust the diff cable as soon as I brought it home. The indicator on the dash would flash back and forth between turf and diff lock. I adjusted the cable like the service manual says and the dash indicator seems to work properly now. I jacked up the rear end of the buggy and when I put it turf mode and spin the drivers tire the other side doesn't spin. In diff lock mode both tires will spin. So I think I have it adjusted properly. Although in turf mode, if I hit the throttle hard enough to spin the tires in gravel or soft grass I will still get two marks in the ground. The drivers side seems to be more pronounced than the passenger side. Does this seem normal? I thought turf mode would only drive one wheel regardless.
ODAMO
ODAMO
1,177
3,206
That is perfectly normal and would leave less of a mark if you had actual turf tires. However it's also why you can go so far off road in turf mode......Its a potent machine alright !
Reactions: treeguy27
WagginTail
WagginTail
1,474
5,459
SC
It's like a limited slip differential while in turf mode
Reactions: Scoop and treeguy27
