P1000m3 30" tires?
Boomboom907
596
620
Washington
Does anyone have 30" tires on a 1000 with HL a arms without a lift?
You need the lift. They will fit without but they are gonna rub Everytime the suspension compresses when you hit a whoop or something to that effect
Sent from my Pixel XL using Tapatalk
P1k
P1k
19
21
Texas
I'm running 30" blackwater evolutions with just the HL arms. No rubbing at all and you keep a low center of gravity with no lift.
IMG 0159
GlockMeister
GlockMeister
The Bearded Wonder
7,604
35,567
Greenville, Mo
What's the largest size evo you can go with.. with no lift or arms?
DrF is running 28s . But I think the 30s are almost the same size I'm the evos.. @joeymt33 you're the tire height expert.
Reactions: JTW
You mean the 30's and 28's are the same size or the 30's are the same as the BH 2's?
39,079
The 30" Evos are slightly taller depending on inflation pressure.
The 28x10x14 was 28.25" tall on a 1300 pound P700 at ~8-10 psi.
The 30"x10"x14" was 28.5 or 28.75" tall at ~10psi.
harrelljr99
harrelljr99
74
122
I'm running 30" blackwater evolutions with just the HL arms. No rubbing at all and you keep a low center of gravity with no lift. View attachment 32502
I just put 30" bighorns on today since I installed hl a arms last week. I had the same thoughts on maintaining the lower center of gravity without lifting.
Thanks for the picture looks good!
Boomboom907
596
620
Washington
I just wanna throw this out there for anyone looking at the intimidators. They are perfect in every way except one.
They flake if your gassing it and they catch on rocks. It's not a huge deal, but they certainly don't wear like iron.
High lifter arms, 2.5 inch lift and 14 inch rims. No rubs. No problems perfect fit. I just want itp to make a 30 inch xtr. Is that too much to ask for?
Honda1000-5
Honda1000-5
216
342
New Brunswick Canada
Reactions: Superthrill
