P500 4+3 rim guys step inside...
SchockSquad
Nebraska
I was finally able to get a few decent pics of my new tires and wheels. Exact same setup GreenBush went with - 26" ITP Blackwaters on the Delta Steel 4+3's. Very happy with them so far. Thanks 906UP for your help with the part #'s and lug nut info.
@GreenBush - if you get the chance, take a quick run around in your stocks before swapping. I wish I would have and would be interested in your thoughts on any difference in ride. I hadn't been out for a few weeks before swapping, so didn't have a good "feel" for the change. I'm running 7 psi.
IMG 0137
IMG 0142
IMG 0143
211,920
View attachment 79618 View attachment 79619 View attachment 79620
I really like my Black Waters, don't ride much pavement. I had some 8 ply EFX's stock size and kept busting the front tires, bought rims and running the same size tire from and rear, no more busted fronts, may try Roctanes next?
Reactions: trigger
G
GreenBush
40
57
The Motor City !!
Will do, Schock...... Heading up on the 4th and right after a couple quick rides, they'll go on.. :cool:
....and the Strongmade bumper, Superwinch 3500, LED light bar, OEM rear window, cup holders, etc.....:p
Reactions: trigger
G
GreenBush
40
57
The Motor City !!
Hey, Schock....the Delta center caps didn't work with the setup or you just didn't want to use them ?
SchockSquad
Nebraska
I thought I would try them without the caps first. Can always order them later if needed.
