P1000 50" LED Light Bar
SmokeyMike
20
30
Central Florida
I have installed a 50" light bar which is about 288Watts
Do I need to use the relay on the harness that I ordered with it or can I just wire to my rocker switch and then to my fuse panel that I added? If OK to wire to the fuse panel what size fuse?
Thanks in advance for any info
samiam
samiam
20
Prescott, AZ
Yes, use a relay. They're $5.
How to determine amps: Watts/Volts = Amps. 288W/12V = 24A
Reactions: ohanacreek and BWAF
urbancoyboyja
urbancoyboyja
Buckle Up, I Want To Try Something...
182
389
WV, USA
My light bar is the same type and rating. I used a relay and a 20amp fuse......
urbancoyboyja
urbancoyboyja
182
389
WV, USA
E9a8c5eaf29045b7bdf051f98c1b7d53
Reactions: Rohr84
urbancoyboyja
urbancoyboyja
182
389
WV, USA
What size light bar is that and where did you get the mounts for it?? Tia
52" curved light bar from Amazon. I got the mounts off a guy on here or facebook, Matt Marrs (Redbank34). I had to ream out the slots on the mounts a little to get the light bar bolts in.
Reactions: Rohr84
