P500 500 versus 700 if price same?
gatorguy
gatorguy
98
404
53
Florida
One thing that hasn't been mentioned hardly is the transmission difference. I grew up with Honda four wheelers with the 5 speed transmissions. I greatly prefer the 5sp to the 3sp auto in the 700. My neighbor has a 700 and I find myself missing the 5 gear selections. Even though it is lighter with less hp, I would trust the 500 for work more than a 700. I've pulled around some big logs with my P5 in 4wd and 1 or second gear. The tranny reminds me of my '99 Dodge with the cummins - 1st is so low I only use it pulling a load etc.
nctrailboss
nctrailboss
440
1,454
north carolina
My dealer doesn't like the 700 pioneer-Rincon tranny.
Alan aka Davinci
Alan aka Davinci
Mr. Meme Master
16,808
183,554
Grand Junction, CO
Is the tranny in the 700 the same as the tranny in the Rincon, I know it's the same motor, I really liked my Rincon when I had it but you did not have a low enough gear on long and steep hill descents and I don't like riding brakes on downhills, it can shorten your lifespan.
Reactions: DG Rider
43,567
Yes, but with lower gearing in the subtranny. If you remember the "Big Red" gear reduction the Rincon guys were doing, it has that from the factory...just like the Big Red LOL!
Reactions: Alan aka Davinci
jwfirebird
jwfirebird
927
1,446
western ny
they pull a ton, I have personally pulled twice the rating a ton of times. going down hills and decelerating is the same as any ebs system ive had you only have to brake on the worst slopes
Reactions: Mudwing
Baldeagle
73
AB
Same tranny different gear on back end to give it lower gearing. Brakes on the p700 are design to be used lots and work great.
Reactions: Mudwing
Baldeagle
73
AB
If I could get a 2018 700 deluxe for slightly more than. 2019 500, would it be worth it? Pros and cons to the 700 versus 500 other than bigger engine?
Thanks
P500 is a great machine. A little tippy. Should widen stance with offset rims or spacers or both. Needs a little lift as well. Both a 500 and 700 would be the best answer. Going for 1. If your trails allow go 700.
Reactions: Mudwing
