if 50" trail limit is not an issue for you and you have more than 1 passenger then go with the larger machine, if you want more speed then go with the larger, that is the only con of the P5.If I could get a 2018 700 deluxe for slightly more than. 2019 500, would it be worth it? Pros and cons to the 700 versus 500 other than bigger engine?
Thanks
I have owned both. If you have more 50 inch trails in your area or want maneuverability in tight areas 500 all the way. If not 700 rides a lot better with more ground clearance with a nice bed. I have 700 deluxe now. I am more then pleased with it. Power steering , diff lock makes it nice . Also clears 27s no problem. Also very stabil due to extra width. They are both excellent machines.
Much better than my 500. They key in my opinion is don t go to fast for conditions . I have 27 inch tires on 12 inch rims which also helps a decent amount. It's good enough I am not going to spend 1400 dollars on shocks at this point. I traded my 500 because I would have to spend a chunk to get the ground clearance , the improved ride , power steering , diff lock . They bed is much easier also to secure stuff . Don't get me wrong I liked my 500 and sometimes wish I had it. But I also have no regrets and feel the 700 is much better in all conditions . I could buy what ever I wanted but I am past the point where I have to have the biggest and baddest and really like my mid-sized machine , it may have to work a little harder but it will do it.How does that 700 ride on ruff trails compared to the 500? I’ve been kicking around a 700-2 not a deluxe for a better trail ride, I’ll keep the 500 just been thinking of selling my old rancher and getting the 700
I had a bad experience with my 07 Rincon 680 motor. 3 cam shafts in 10,000 miles. Almost 9,000 miles on my p500 no problems.If I could get a 2018 700 deluxe for slightly more than. 2019 500, would it be worth it? Pros and cons to the 700 versus 500 other than bigger engine?
Thanks
Another cam on FB this morning.I had a bad experience with my 07 Rincon 680 motor. 3 cam shafts in 10,000 miles. Almost 9,000 miles on my p500 no problems.
From what I read, people with 500's are passionate because it fills a specific need and for good reason.
Whether it is hauling it in the pickup truck or maneuvering in tight spots, it is a great, compact machine.
Places you want to go and how you plan to haul it , dictate the width limits of the machine.
If none of that matters then the 700 gives you more flexibility now and in the future.
Good luck and doubt there is a bad choice.
sorry but this don't sound that bad to me, 3-4k on a bike motor that sees many thousand rpm between having to mess with it don't seem that bad. might be something with the heat breaking down the oil, who really knows, don't seem like they have found much in common in the threads I looked at, certainly not enough to stop me from buying it. with the common trans you probably just have more wear there in the tc from shearing seems like it was hot parts of the country and they have the trans wear. I am just going to do my $20gl Valvoline atv twice a year and see what happens.Another cam on FB this morning.
It may not be bad in some places, but that's 2.5...maybe 3 years of riding for me ( and many, out west). If Honda told me all I could expect was that type of mileage, I'd go buy a Yamaha. And @Farmer and some others had low milage failures.sorry but this don't sound that bad to me, 3-4k on a bike motor that sees many thousand rpm between having to mess with it don't seem that bad. might be something with the heat breaking down the oil, who really knows, don't seem like they have found much in common in the threads I looked at, certainly not enough to stop me from buying it. with the common trans you probably just have more wear there in the tc from shearing seems like it was hot parts of the country and they have the trans wear. I am just going to do my $20gl Valvoline atv twice a year and see what happens.
