Boxliner & Tailgate liner Version . ( cut down to fit on P500 rear rack.)
Older Over the Rail style are of thicker plastic.
Does have tilt option built in -- although have it bolted down & donot use.
1in. Sq. tubing framework fabricated to accommodate the cut down Boxliner attaches to the P500 rear rack .
Box liner bolted inside the 1in,. tubing frame.
ALL accessories attach to tubing frame
24x48x4 ALUM. Box attached to top front provides plenty of storage & chainsaw carry location.
ALUM. Box in the rear slides in & out as needed & still have storage under the top box ( held in place between ft. box & tailgate ) tight fit only requires 1 strap across top.
Using 1in.sq. tubing & plastic kept the weight down.
Remove 6 bolts & ALL is GONE as a Unit. ( back to just the P500 rear rack )
Pictures tell it Best.
