P700 700-4 dual or big battery
infyx
infyx
62
106
Maine
Went with the NLP20 from Noco. Will report back. Bought from Amazon for the hassle free returns should it not work out.
Reactions: CID and Remington
5,756
26,439
I have a stock 2021 700-4D. I have my heated gear from riding my motorcycle, which I no longer ride, and was thinking I could use the gear for winter sxs rides. Will my stock battery be able to handle this accessory or do I need a larger capacity battery?
It’s not the battery that has to be up to your heated riding gear, the alternator/stator has to be able to handle the load. Other than short uses, maybe like plowing the driveway, any battery will die trying to heat your gear if the charging system can’t handle the load.
You need to know how many amps are available from the 700 and how many the heated gear uses to know if it will work. Found it, the 700 has 37 amps but some of that runs the buggy, so your gear has to draw less than about 25 amps (a wild azz guess).
Sudani
14
37
Arkansas
Thank you. I’ll check my Gerber gloves and liner jacket for amps required.
Reactions: CID
Sudani
14
37
Arkansas
Gerbing! Ok, Amps: I should be ok.
  • Power: 12V DC 1.1 Amp Each Glove
  • 2.2 amps for gloves
  • Jacket Liner:
  • Power: 12v DC 6.5 Amp
Reactions: CID
jsahara24
42
139
PA
Does anyone know how does the LifePO battery charges in the winter? I thought they needed to be above freezing in order to charge.
infyx
infyx
62
106
Maine
People use them in solar setups. I am up in Maine, so I can report back on that too!
jsahara24
42
139
PA
Yeah but I think they keep them in the cabin where its heated. If its left unheated when they leave I think they disconnect them, but I'm far from an expert on the subject.
5,756
26,439
Hmmm, I don’t have a clue. 🤔
Your heated gear draws a lot less than I thought. My buddies have suggested the same idea for me.
Reactions: Sudani
infyx
infyx
62
106
Maine
So I reached out to Noco on this.
They said “Storage and operating temperatures are rated at -4F to 140F (-20C to 60C)”
Reactions: CID
jsahara24
42
139
PA
That's good to hear! I wonder how they are doing that, I'll have to look into it more.
Reactions: CID
infyx
infyx
62
106
Maine
She indicated if the battery detects temps outside of that range, it shuts itself down to protect itself.
I’ll give it a go. Hoping it works out because it seems like a really nice battery! Thankfully it’s winter now, so should be able to start testing day 1.
Reactions: CID
infyx
infyx
62
106
Maine
First report.
the terminals are flipped on this battery.
the stock wires won’t reach because of this.
So I either need to cut and extend the stock wires or just use this battery as a second.
leaning towards second battery at this point. Seems easier.
anyone ever put the second battery in the glovebox? This thing fits perfect in there…
jsahara24
42
139
PA
I looked up the users manual on my prior charging question, they do address it....I am picturing myself out plowing snow, using lights, radio and the winch and the battery not charging....Guess it depends on your climate, having said that the battery can probably handle it anyway as they can be discharged 100% with little negative effect.....just makes me nervous....
"In order to protect the lithium cells, the BMS will not allow charging below -10ºC (14.0°F). Once the battery temperature reaches -10ºC (14.0°F) or higher, charging will be allowed."
I think I would probably make it my second battery, and not sure about the glove box. I don't think I'd be willing to give it up, I put so much stuff in there....
5,756
26,439
Install a digital voltmeter, they’re cheap. If you get below 12.5 volts, turn something off.
Main on top, aux on bottom.
1678154240655
