P700 700-4 height
bluedog
15
I have 80" of clearance where I'm going to store the 700. The 700-4 spec sheet says the height is 78.3". My question is where is the highest point measured from. I'm guessing it's from the rear of the passenger roll bar. I ordered the hard top that covers only the drivers compartment. I'm hoping it fits, I can always lose the rear cage to help make it fit. I was surprised to see that the 1000 is about 2" lower than the 700.
Tflynn
Tflynn
Not a liberal
2,501
3,833
Northern California
Not sure about the p-4 but on my p-2 the hard top adds about 3+ inches. In a worst case scenerio I guess you could remove the roof for storage. Other people have let air out of their tires or even ratcheted down the suspension to get their rigs into their garages!
Reactions: joeymt33
I had to load wood or a few 5-gallon buckets of water.
JakesDad
7
700-P4 almost 84" tall at the back edge of factory roof. Had to modify garage door opening to get it in.
swsebek
swsebek
2,854
5,835
pa
No way your getting in 80 inches,the later if you want bigger tires....
allgm1
allgm1
1,049
1,484
New Hampshire
LOL I can drive in to my garage, it just barley rubs but to back out i have to get out and pull down and back on the rops to get it to clear. I ended up adding two doors to my shed to fit it in side
Gator
Gator
The Most Unknown Member
2,488
10,464
Louisiana
My shop door is 10' so no problem. But... I was looking and I could raise the door about 6" and it would still reach the ground when closed.
Might look at that.
Tflynn
Tflynn
Not a liberal
2,501
3,833
Northern California
Might look at that.
Got a big suspension lift in the works?? Haha
bluedog
15
Well, I got it in the garage. I had to unhook the garage door from the opener, remove the opener bracket from the door, and use a 2x4 to prop the door open past the door frame. I also had to take the hard top off the 700. I think it would have made it in the door with the roof, but it would have hit the rubber weather seal on the garage door frame. I think I can move the mounting brackets on the back of the roof higher, which would put it tighter to the roll bar, and lower the roof an inch or so. This would also require me to cut a little bit of the roof. If it doesn't look like that will work, I will sell it and go with a soft top.
Gator
Gator
2,488
10,464
Louisiana
Sounds like a pain. I think Tflynn has been working on a lowered cage. Maybe he will share his design.
d_b
d_b
302
240
Chop the top, its fairly easy. Or just build a better one.
d_b
d_b
302
240
I had to let some air out of the back tires and put some block in the back just to get it in my garage.
Why not just racket down the front end, you can get two to three inches on stock suspension.
Johnny
Johnny
Well... I just found out the hard way. I can barely, slowly back in my garage with my 700-4. But after using my new snow plow, decided to back in like usual, wouldn't fit.
The weight of the plow caused a big crunch sound as I cracked the wood frame with my taller rear height. I didnt think about that. So, after fixing the door frame, I lowered the plow to the ground and backed in, tight and touches but doesn't damage anything.
Gator
Gator
2,488
10,464
Louisiana
OOOOH! Man.
Hey someone should market a lowering kit for the Roll Cage.
d_b
d_b
302
240
OOOOH! Man.
Great idea. Just way to much liability, already thought of it. Maybe sell plans for someone to do it them selves ?? Hmmm.
Gator
Gator
2,488
10,464
Louisiana
Hmmmmm.
Might need a disclaimer.
Lowering the roll cage could cause brain damage, cancer or death.
d_b
d_b
302
240
I believe its your turn @Tflynn lol..
Reactions: Tflynn
