P700 700 camshaft issue
Samre
  2. Big Red
Hi, i am pretty new to this and I know its probably in the wrong place but... Is there anywhere to buy a complete rebuilt engine for a Honda MUV700, 2013 ...
Thanks for any help.
Farmer
Farmer
2,975
17,169
Southern MO
I have a 2015 pioneer 700-4 that I am currently troubleshooting. It idles perfectly, but when I press the accelerator I can only get up to about 6-8 mph then it seems like the limiter is kicking in in Drive. Is this the issue that the cam change fixed??
Yes, but check the exhaust and everything else 1st. How many miles does it have? They usually go out early if they're going to. Edit.....early if it's from the same defect. Cams can go for a variety of reasons but if you have low miles and it's out...... you have every reason to ask for compensation.
Farmer
Farmer
2,975
17,169
Southern MO
I've never taken one apart, so this qualifies as a WAG question . . . wonder if they changed anything with regard to cam lubrication? Oil gallery ports, etc. Honda usually, but not always, gets things right. On my S2000, they found that running above 6,000 rpm for over 30 minutes (IIRC), caused oil starvation to the rear and maybe front piston rod crank ends. The fix was increasing the size of the oil ports. If you don't run motocross, you'd never experience a problem. I don't, so haven't bothered to do the upgrade.
The main consensus is that there was a surface hardening issue that went on for far too long before Honda showed any interest. The cams literally sit in a cup of oil so all signs point to manufacturing defects vs lack of oil. The weird part was the randomness. Mine went out at 680 miles under very limited and basic use. No high revs or beasting in the mud etc.
Farmer
Farmer
2,975
17,169
Southern MO
If your cam is bad.....make sure you're getting a recently made part. With parts etc being hard to get, I'd hate to see you get an old dusty "bad one" from off someones shelf.
P
price1983
Columbus Georgia
Howdy. Been reading threads regarding the Pioneer 700 camshaft issue, the issue where the cam lobes round off. I suspect I have this issue with my 700 and so I will be replacing my cam. Question is - is this something that has been resolved?? My understanding, based on the other posts about it, is that it was some kind of 'issue', common with our machines (that the cam lobes wear). I mean I'd hate to go through the work to replace the cam later to find out I should have used some 'upgraded' version of the cam or something, and end up in this same boat again down the road. Anyone have experience with this situation that could add some detail? Thanks much all
Hello. I have a 2020 pioneer 700. I've had my camshaft replaced by the dealer right after my warranty ran out 4,000 dollars got it back 13 months later it went out again it has 3,800 miles on it! Ridiculous!
P
price1983
Columbus Georgia
Hello. I have a 2020 pioneer 700. I've had my camshaft replaced by the dealer right after my warranty ran out 4,000 dollars got it back 13 months later it went out again it has 3,800 miles on it! Ridiculous! I want an explanation and my money back at this point.
500oneer
500oneer
15,000 mile club
429
1,088
Central PA
Honda isn’t going to do anything about this. They have know about camshaft problems since that motor was in the rincon atv. Factory reps have been denying it for over 15 years. $4,000 sounds high for just a cam.
P
price1983
Columbus Georgia
Extreme power sports of Columbus Georgia where I purchased it and that's who fix it. I agree I could have got a whole other motor.
Reactions: Farmer and 500oneer
Hello_Darkness
Hello_Darkness
666
2,679
Just to the right of nowhere
I literally could've built you an engine from the crank up for under $4k
Camshaft replacement usually cost under $1k, way under. Unless they removed and cleaned engine out, but even then $4k is high.
DRZRon1
DRZRon1
1,434
4,395
PA
who do you want an explanation from specifically and what recourse are you taking to get your money back ?
DRZRon1
DRZRon1
1,434
4,395
PA
I’m just amazed it only took 13 months 😂 for a couple hour job 😂😂😂
Farmer
Farmer
2,975
17,169
Southern MO
Im just saying I'm fed up with this Honda parts were under a thousand but the rest was labor.
Uh yeah you need another dealer. Sounds like they had the intern working evenings on it. I wonder if they set the valves right on the 2nd one???
