700Muv starter problems
Rdotts
Indiana USA
I have a 700 mug and the starter bangs hard and will not start. I have replaced the battery and the starter what else could cause this
Reactions: TxDoc
Alan_Vander
Alan_Vander
1,547
2,750
rosepine,la
Could be the starter selenoid getting weak by hitting hard im guessing the bendix is kicking out but your not turning the motor?
Reactions: TxDoc
Alan_Vander
Alan_Vander
1,547
2,750
rosepine,la
I would open the rear and turn the motor just to make sure its not the motor. I really hate to say it on something simple but i always like to cover every possibility.
HondaTech
Honda starters are always directly connected, no bendix required.
Sounds like the gears are bound up or didn't get lined up properly at some point
Reactions: wrhii
bigshoe
bigshoe
421
1,426
Definitely make sure motor isn't locked up, but there is no bendix starter turns a one way bearing on crankshaft.
Reactions: wrhii
bigshoe
bigshoe
421
1,426
Easiest way to ck solenoid is take screw driver and jump across 2 big terminals on solenoid if it still make the noise and no crank theres something wrong with starter or engine is locked up
Alan_Vander
Alan_Vander
1,547
2,750
rosepine,la
Might have the wrong word for it but then again i havent tore into my starter before. The starter gear and flywheel are always touching?
bigshoe
bigshoe
421
1,426
Its a one way bearing when starter turns it will lock up going forward once engine starts it will act just like a normal bearing and just spin
HondaTech
Yeah, that's the reason they have a starter "clutch" that allows the flywheel gear to freewheel when running.
Reactions: Alan_Vander
bigshoe
bigshoe
421
1,426
Its a really good system. I have been on atvs leaning up over handle bars climbing hills and hit the button and it will cause no damage a bendix style can and will blow the starter out or crack the case
Rdotts
Indiana USA
I took the starter off and looks like the shaft of the starter is stripped off and maybe the bearing gears is my problem how hard is this to replace
HondaTech
The starter gears can be accessed by removing the stator cover and flywheel.
Take the right rear wheel off and you can do it in the unit. If you jack it up high enough you won't even lose any oil.
