P1000 Sagging top & a new Tire Carrier Rack
O
ob1jeeper
96
279
53
Arizona
When I purchased this P1K-5, it had a roof mounted light bar of aprox 30-36 inches long. While I am not a huge fan of these large lights, it is what it is... Anyway, the weight of the light, coupled by softening of the top material in the heat/sunload, was causing the front edge of the roof to sag, and interfere with the folding windshield, making folding it a PITA. To fix this, I fabbed up a small tube to place beneath the leading edge of the top, just below where the light is mounted, which is in turn attached to the ROPS, just outboard of the gusset in the "A"-pillar-to-upper horizonatal ROPS bar.
IMG 8623
Another top sag issue was in the center of the top. The issue was that everytime I washed the vehicle, then tried to move it, I was getting a bath from the pooled water in the center of the top... Grrr... So I fabbed another top anti-sag support, mounted to the central lateral ROPS bar just behind the front seat. The white strip you see, is an LED strip light, to provide interior illumination for night use... ;)
IMG 8622
There are obvious paint/powdercoat damage marks where at one time this vehicle has some sort of rack installed to the rear ROPS. When I bought it, there was a Dragonfire aluminum spare tire bracket hanging from the rear upper ROPS bar, mounting the spare tire/wheel. I was no huge fan of this spare location, so began to look at other ways to mount it, when I ran across some designs others have utilized, and which I liked. I selected some features from a few different racks I had seen, which I felt would best match my fabrication abilities and be simplest for me to build. I decided to mount the tire, and a small rack for a cooler aft of the bed, on a rack system which could be swung out from either side, to allow for cleaning and/or dumping of the bed.
This is what I ended up building...
IMG 8050
IMG 8048
IMG 8614
IMG 8615
IMG 8616
DDDonkey
Nice job, what size tube and wall thickness did you use, I have been thinking of doing something like this my self.
Reactions: Isaiah
