Avoiding the Rats Nest of Wires Using Remote Terminals is a great idea as well as the jumper cables. Will you still Run a Dual
Battery Set Up? Can't wait to see your build. So...Get started what are you waiting for? Lol
I don't plan on doing a dual battery set up. I like the idea of a dual battery set up, however I am trying to reduce weight on the front of my vehicle and add more capacity for winching. There was a fault with the dual battery set up and using two small batteries. Under real hard winching, my voltage would drop below 11 volts so the winch is not pulling as strong as it could.
When using a battery isolator and two small batteries, The winch would pull the voltage down enough so that the isolator would break the connection between the two batteries and then I was wincing off of only one of the small batteries.
I had the full-size optima battery set up in my pioneer 700 and I did not have voltage drop issues like I do now with the small batteries. For safety concerns, I can carry one of those very small lithium ion jump packs.
As far as getting started, I need to find enough time at home to do this project. I'm currently working in North Carolina and maybe can get back to work on the pioneer this weekend. I've got two projects ahead of the battery project. I still need to finish my foot and firewall protection and then replace a leaking pinion seal on the rear differential.
