P1000 Accessory power from backup alarm..
DPort
DPort
170
266
Lincoln, ME
Got ya..
That's the answer I was looking for..
so I'm surprised the 12volt accessory plug isn't heavier wire. Shame there isn't a subharness for the 1000...
I found connectors and seals for mine and ran the B/U signal and 12V signal wires together to the front in 18ga. wire
to run relays.
Reactions: JTW
ToddACimer
ToddACimer
Pioneer 1005-2
3,736
15,793
Oshkosh, Wi
The 700 accessory harness 08Z02-HL3-A00 plugs directly into the harness on the 1000 under the rear seat and behind the engine. This allows for plug-in power for a reverse light
Reactions: Jshell3
Jshell3
Here's what @ToddACimer and I came up w/... (Mainly Todd - because I got confused)
IMG 4649
I wound up clipping the "to lights" ends off and crimped on a universal quick connect. Taping up the rest, I made this funky looking harness.
IMG 4746
Btw- harness is like $10.
Jshell3
Green end of harness plugs in here... in front of rear driver's tire just above the oil filters... Looks like this.
As it was discovered...
Plug
After I unwrapped it.
Plug showing wires
If I had it to do over again, I'd probably just posi-tap the wires, and turn it into a $1 quick connect harness... faster / cheaper.
IMG 4747
Reactions: Eltobgi
