P500 Added some accessories
T
Twitch
37
38
In the backyard
Been lurking here for a while and finally joined up. Already did my own roof out of 0.25" uhmw and a two piece windshield out of 0.25" Marguard lexan. Here's what i've been working on lately....
IMG 20160526 180753 873
IMG 20160526 180812 382201
IMG 20160527 160848 040
182,090
Welcome to the club Twitch!
Nice work under that hood... second battery, very clean job.
Nice to see someone else get creative with the sound system too.
That's right about where my sub fires in the toolbox. Turn it up!!
T
Twitch
37
38
In the backyard
Thanks. I figured that was unused real estate, so why not. I did the 6"PVC caps, trimmed an inch off them so the whole setup wouldnt stick to the front or the back as far. I added polyfil to them and got them sounding better. Just in the caps alone they had a tin can sound that i didnt really care for. The caps are set in .50" aluminum. I drilled all the way up from the bottom to run the speaker wires into the caps so there would be no wires sticking out. Then sprayed it all with rattle can bedliner.
I used the 2 channel Pyle amp. Its mounted in my overhead switch mount. Had to put everything up there because I have a little guy that loves to ride but likes pushing buttons even more. Thats why i went with a wireless remote for the terra45 winch and mounted the wired remote socket in the underhood panel.
My next project will be a saw mount so I'm not just strapping it to the back all the time. Then maybe redo the skid plates out of UHMW, then maybe some driving lights in the matching guards i made to cover the brake master cylinder, oh crap the list keeps getting longer.....
Reactions: trigger
182,090
It never ends...these things are a blast to accessorize.
p500fan
p500fan
417
354
Sand Point, AK
I love the second battery setup. Looks like a textbook job. I have toyed with the idea of putting a second battery, or just moving (and going larger) to under the hood. Haven't had any problems with factory, so I have put it on the back burner. However, seeing yours lights that fire, again. Ha!
Reactions: trigger
T
Twitch
37
38
In the backyard
I have a bad habit of going off somewhere and leaving radios playing so I figured it was better to be safe than sorry.
182,090
Same here, I've been kicking the idea around for a while. Is it as simple as wiring the two in parallel? Hot to one, ground to the other and jumpers in between? That's how I added the second battery on the travel trailer. Essentially makes the two batteries as one just more power storage capacity. Supposedly charges the two batteries equally.
I can provide you a blueprint if you need, lol.
No it's not trig, check out my dual battery thread. P500 - Dual battery
273,307
@Twitch nice looking ride. Having a second battery with lots of powered accsy. is a smart move.
Damn Monte...that's bad ass! Can't say that I've ever seen that pic of your ride.
Cover and everything, very clean...nice job.
Yeah, that's the set up I want.
That thread will get you there, you'll find all you need in the instructions @JCart provides!
Reactions: trigger
T
Twitch
37
38
In the backyard
Now that is a clean job Monte! I'm a fabricator, not an electrician! I have spent today making a template for a one piece skid plate. Made one out of cardboard, think I'll run the first one out of ply board on the water jet. If it turns out good I have to make up my mind whether or not to use the 1/4" UHMW I have left or buy another sheet of 3/8" UHMW. I bought a 4'x10' sheet of 1/4" to do my roof and have enough of it left to do the skid and A arm guards if I choose. $130 for the 4'x10' sheet and have enough to do all of it. Not bad when you compare the prices of any roof or skids out there.
Reactions: iowaguy
T
Twitch
37
38
In the backyard
Trigger, I just used the stinger relay on mine. I hope the charging system doesn't crap out, prematurely.
I had to put the saw Mount on hold for the new skid plate. Rode some trails Thursday, got high centered and peeled the factory plate down. Guess one of the bolts and recess washers came loose and fell out. Had to winch off the hump. Decided to make my own after seeing solrus's thread on the one he made.
Reactions: Montecresto
Your right. Very nice that you can fabricate and save yourself some beer money for your next ride!!!
iowaguy
iowaguy
624
1,425
Eastern Iowa
I also made a roof out of 1/4 " and used the Honda quick clamps to hold it on,I love it, absolutely no rattles or vibration, it doesn't touch the roll cage anywhere, it sets on top of the clamps away from the cage.
T
Twitch
37
38
In the backyard
I also made a rpiece clamput of 1/4 " and used the Honda quick clamps to hold it on,I love it, absolutely no rattles or vibration, it doesn't touch the roll cage anywhere, it sets on top of the clamps away from the cage.
I made my own clamps out of 1" thick aluminum. Picture a 2 piece clamp collar with a leg on one side. Cut them on a water jet and then did the machine work to make them 2 pieces, drilled and tapped holes. If I get a chance I'll post a pic. Photo bucket hates this phone so it'll be later.
