P1000 Adding Aftermarket Heater
ecom101
ecom101
15
44
Kelowna, BC
ecommediagroup.com
The factory heater is very expensive, especially if the dealer installs it for about a day's labor. I found a 3-speed marine heater for about $220 from Summit Racing and ordered a coolant bypass from Ice Crusher to provide low-engine RPM heat.
I did not run the heater ducts to the windshield or the dash, instead decided the engine firewall was way easier and would still heat the cab nicely. I thought I would share with the forum as it works great!
IMG 5966 IMG 5964 IMG 5963 IMG 5962 IMG 5957 IMG 6002 IMG 6001 IMG 5999 IMG 5998 IMG 5997 IMG 5995 IMG 5993 IMG 5991 IMG 5971 IMG 5970 IMG 5965 IMG 5974
ODAMO
ODAMO
1,283
3,450
Ohio
Sorry, i was away. the hater from Summit Racing was $$204, the hose and duct kit was $48 and the thermal coolant bypass was $80.
There were miscellaneous adapter from 5/8 to 3/4' heater hoses and some hose clamps.
Is that the 28000 btu unit? I see they have a 40000 btu unit also. Does anyone have any indication of how big a heater can be run ?
Bighat
Bighat
887
3,795
Gallipolis Ohio
I almost went that way. The factory heater was out of stock but the dealer said he could get the inferno max. I also got a 10% discount because I was buying a new machine at the time. I think it was about $400 for everything. I went with it because I knew it was made to fit and I wouldn't have any install problems.
I had a UTV before with a glass windshield and cab with no heater and the biggest thing wasn't not having heat as it was the windshield fogging and having to have a rag to wipe it off all the time. I put the dash vents in the new one and I'm so glad I did because the defrost works great. You'll see what I mean if you ride in the cold and wet enough but you can always add it you to yours. What I like about the one you got was the 28000 btu. I have 18000 btu, but more is better in my book.
Buckslayr
141
353
Nd
View attachment 355418 View attachment 355419 View attachment 355420 View attachment 355421 View attachment 355422 View attachment 355423 View attachment 355424 View attachment 355425 View attachment 355426 View attachment 355427 View attachment 355428 View attachment 355429 View attachment 355430 View attachment 355431 View attachment 355432 View attachment 355433 View attachment 355434
have you had a chance to use this and does it heat the cab, I'm in ND and need a good heater, which coolant lines do you splice into> thanks
Buckslayr
141
353
Nd
what cab do you have?
Buckslayr
141
353
Nd
can I get a picture of your vent install done?
Vikes79
Vikes79
SKOL!
11,684
113,328
South Dakota
  2. Talon X4 LV
If you haven’t sealed the bottom of the doors and most of the upper roof gaps with foam, it won’t matter how big of heater you have.
on my front lowers I used truck tailgate seal. Works awesome since 2018.
only thing that sucks about the seals is that you have to stop and open the doors to let the water out after crossing a stream in the summer…
Thread 'Vikes79 Hardwater Honda build'
P1000 - Vikes79 Hardwater Honda build
208,725
Well you don't have to really stop, I think it's a personal thing?
