Yeah... I need to do this eventually. Have all the s*** just haven’t done it.Here are some.pics of my rear knuckles. I have SATV A arms so i alreay have zerks on the front arms.
View attachment 132824 View attachment 132825
@ToddACimer & @GlockMeister
You both used different angled zerks. Is one more accessible than the other? Or was it purely what was on hand when it was done?
The SATV arms cover the top of the knuckle. I used the 90 on top to keep it away from the cv..@ToddACimer & @GlockMeister
Yep..i ground 3 light grooves.@GlockMeister @ToddACimer Are you guys somehow adding grooves/scoring the metal sleeve inside the rubber bushing to give the grease a pathway between the metal and rubber? That's what @joeymt33 recommended and I've done for the front.
How did you make the grooves ..... Lathe?Yep..i ground 3 light grooves.
LOL ..... did not think about that. Did you just make multiple straight lines, or swerle it around shaft?
Just like Joey...used a dremel and a cutoff wheelHow did you make the grooves ..... Lathe?
The way I looked at it is that if you pack the cavity with grease and run it, the temperature will allow the grease to flow into the bushings. When I first removed the pivot pins they came out with water. Adding the groove only makes it easier to get water to flow through.
I haven't compared grooved to not grooved but I know my knuckle cavity is packed with grease and I lubed the shafts going in
But it sure is nice to pump grease in there like I just did about 15 minutes ago and sometimes it does push water out. I don’t cut or groove the seal or seal cap. I just give the grease a path out to the seal.
Anything is better than the original set up. Mine were dusty dry and worn completely out.
On my 2016 the grease flowed a bit better with the pin wear
