P1000m5 Adding zerks...
Dchilds75080
40
65
Richardson, TX
Where have you guys added zerks to your machines? I’m going to add some to my front upper a arm bushings. Considering the rear hubs, too. Any thoughts/pointers/pictures?
Reactions: BWAF
GlockMeister
GlockMeister
The Bearded Wonder
7,604
35,567
Greenville, Mo
Here are some.pics of my rear knuckles. I have SATV A arms so i alreay have zerks on the front arms.
20190415 154040
20190414 172937
13,363
65,124
@ToddACimer & @GlockMeister
You both used different angled zerks. Is one more accessible than the other? Or was it purely what was on hand when it was done?
ToddACimer
ToddACimer
Pioneer 1005-2
3,560
14,609
Oshkosh, Wi
I didn't want my upper under the knuckle. Both spots work.
Reactions: BWAF
GlockMeister
GlockMeister
The Bearded Wonder
7,604
35,567
Greenville, Mo
The SATV arms cover the top of the knuckle. I used the 90 on top to keep it away from the cv..
But a 45 would have worked in both spots.
Reactions: BWAF
Dchilds75080
40
65
Richardson, TX
@GlockMeister @ToddACimer Are you guys somehow adding grooves/scoring the metal sleeve inside the rubber bushing to give the grease a pathway between the metal and rubber? That's what @joeymt33 recommended and I've done for the front.
Reactions: BigOL3 and BWAF
GlockMeister
GlockMeister
The Bearded Wonder
7,604
35,567
Greenville, Mo
Yep..i ground 3 light grooves.
Reactions: BWAF
BigOL3
BigOL3
2,994
8,919
How did you make the grooves ..... Lathe?
39,079
LOL ..... did not think about that. Did you just make multiple straight lines, or swerle it around shaft?
I just made sure I cut a groove from one end to the other so the grease could make it all the way out to the seals and push water out. I did not do any swirl pattern.
ToddACimer
ToddACimer
Pioneer 1005-2
3,560
14,609
Oshkosh, Wi
The way I looked at it is that if you pack the cavity with grease and run it, the temperature will allow the grease to flow into the bushings. When I first removed the pivot pins they came out with water. Adding the groove only makes it easier to get water to flow through.
I haven't compared grooved to not grooved but I know my knuckle cavity is packed with grease and I lubed the shafts going in
Reactions: GPR1500SC and JTW
39,079
But it sure is nice to pump grease in there like I just did about 15 minutes ago and sometimes it does push water out. I don’t cut or groove the seal or seal cap. I just give the grease a path out to the seal.
Anything is better than the original set up. Mine were dusty dry and worn completely out.
Reactions: JTW
ToddACimer
ToddACimer
Pioneer 1005-2
3,560
14,609
Oshkosh, Wi
On my 2016 the grease flowed a bit better with the pin wear
Similar threads
