P1000 Ag sprayer in bed
17LE
17LE
79
202
Iowa
Does anyone have comments on putting a spray tank and electric pump in the bed.
I"m curious if the charging system will handle it with out adding a second battery ?
Would be interested in pics or comments on how you did your set up.
Thanks !
Vikes79
Vikes79
SKOL!
11,709
113,610
South Dakota
  2. Talon X4 LV
The pumps on the UTV size sprayers don’t really draw that much power.
A heater fan motor draws way more power in comparison.
I usually just pull my battery out of my lawn mower cause I don’t want to string wire to under the hood. This is something else you could consider too.
17LE
17LE
79
202
Iowa
Thanks for the replies. I have a 26 gallon for my atv, its tired and so am I of mounting it and continually filling it.
I'm thinking of going with an Enduraplas or F/S Manufactuing, for a little more capacity.
17LE
17LE
79
202
Iowa
Here's what I ended up with.
IMG 1116
115,721
Just seen this thread lol.
I have a 20gal electric pump sprayer I put in my bed that I use for fertilizing my food plots. I just put a small battery in the bed and hook the alligator clips to it. like said before, they draw low power so if u hooked to your secondary battery I don't think you’ll have issues.
Reactions: Isaiah and 17LE
BBB
BBB
270
1,320
Northeast Illinois
The biggest electric sprayer pump I found only draws 23 amps at full load. That's at 9 gallon per minute, my 5 gpm runs through a 15 amp fuse, and I haven't blown the fuse. No need for a second battery.
17LE
17LE
79
202
Iowa
I ended up just setting a group 30 out of a tractor in the bed. I have a few of them around so that's the easiest.
Ran about 3 tanks through it so far.
It did come with brackets for a spray boom but I took them off.
Reactions: Isaiah
