P1000 Air Filter Change at 3300,p1000-5,2020.
Scamih
303
814
Marshall Illinois
I changed my filter at 3300 miles which was 4 years and it was pretty dirty. I’ll change at 2 years going forward. When I put housing back on, one of the top bolts wouldn’t tighten up. I haven’t taken it back apart to check it out. Anyone else have this issue. Is there a trick or an insert you can put in housing. I think it will be ok but I’m thinking down the road when I go to put a new filter in in 2 years.
  • Wow
Reactions: Remington and TxDoc
116,574
Do u have a pre filter?
Thats a awful long time if u dont. Im willing to bet its pretty dirty way before that
Scamih
303
814
Marshall Illinois
I’ll doing it every 2 years here on out. No prefilter just what came on machine. I thought book said 3600. Back to my question. Ever have trouble with getting a bolt to tighten up?
  • Wow
Reactions: Remington and 906UP
Martoe
12
17
Alberta,Canada
Sounds like a lot of miles and time before changing to me. Ill clean mine along with fresh oil at 500km.
906UP
906UP
15,066
143,210
da Yoop
Is the insert spinning in the backside of the filter box?
Mopower58
Mopower58
TRUMP 2028
88,385
756,185
Crystal Springs,Ms.
If the insert is spinning in the housing, remove it from the housing,hold it with channel locks, take a housing bolt and run it back and forth through the insert from the opposite side. This will clean up the threads. Reinstall the insert and carefully start the bolt.
Reactions: 906UP
P1K5Dave
P1K5Dave
2,336
8,718
Petoskey, MI
Mine had one that felt like the insert was spinning in the plastic housing.
Once I got it apart, I found that the insert was still firmly mounted in the plastic. It turns out it was the actual screw and threads that were stripped out.
That insert appears to be pretty soft metal.
I was able to replace the screw with a new one and run a tap into the insert. It's holding well, surprisingly.
116,574
Id still check it every oil change at least. You might be surprised especially without a pre filter.
Also, dont forget to hit “reply” or tag @Scamih when responding to post so that person gets a notice like you did. I just stumbled on this post again and your answer to my last one was 3 days ago
Reactions: CID
