P500 Air filter
Jdurbin
How do I go about removing the air filter? I've taken the cover off, loosened the clamp, but it doesn't want to budge. There is a plastic piece above it. Should that be removed first? If so, how? Am I being too soft on it? I don't want to break it. Also I've noticed that it needs to be greased after it's been cleaned. What kind of grease should I use?
67,170
Yes, remove the black plastic piece. The filter will most likely come out with it. You need to buy foam filter oil. Just a light coat on the outside. The grocery bag method works great.
Jdurbin
It just pulls right out?
67,170
Yep.
Full
MaleRN28US
MaleRN28US
271
125
Roanoke, Indiana
What exactly is the "grocery bag" method for those of us that are not familiar with it?
67,170
It's just a trick to oil a filter without making a mess.
Step one... The most important step!
You need to go to the grocery store and pick up a 6 pack. Now you have a plastic grocery bag.
Next. Pour or spray some foam filter oil inside the grocery bag. You need enough to get on the bag walls but not so much it puddles up.
Next insert clean dry filter. Lightly rub the oil from the bag walls onto the filter leaving a light coat. Be sure to get it all coated
Remove filter.
Done.
The spray works fine just using it alone. But you have to be careful not to over concentrate it. Grocery bag method helps with this to insure a full coat.
wyo700
wyo700
413
210
Yeah you left that part out. Surely drink them all while doing the grocery bag method seems to make sense to me.
Reactions: bobbyhill
MaleRN28US
MaleRN28US
271
125
Roanoke, Indiana
I couldn't drink 6 beers and still "function" and I surely could never drink them that fast.
Reactions: JACKAL
273,269
Well your status with a six pack as a HONDASXS "Red Rider" is still amature. :p A few thirsty with us trips in August heat we can see if you make Pro :D.
Bottoms Up:cool:
bobbyhill
bobbyhill
Junior Moderator
1,271
953
Smithfield, VA
the bag method must be why some guys clean there air filter after every ride!!:D
MaleRN28US
MaleRN28US
271
125
Roanoke, Indiana
Bottoms Up:cool:
Lol, thanks. I just try not to drink too much. Working in the Emergency Room cures you of a lot of habits. Too many memories.
Reactions: JACKAL
273,269
Very True, just because you hold a beer doesn't mean you have to be "that guy" who says hold my beer and watch this. Used as a refreshment and not liquid courage requires juris prudence.
Reactions: hambone
sgerksinwi
sgerksinwi
203
264
WISCONSIN
I know this is a old thread.What is the best way to clean the foam filter? Stuff from the store or soap and water??
906UP
906UP
14,391
136,736
da Yoop
I fill a bucket with warm water & Dawn dish soap(cuts the grease/oil). Stick the filter in the said soapy solution and shake like crazy.....repeat as necessary. Rinse with clean water and air dry.
Reactions: sgerksinwi
273,269
I had traditionally used gasoline, wring and rinse out until clean, let it dry then re-oil using a plastic bag to keep hands clean.
906UP
906UP
14,391
136,736
da Yoop
I had traditionally used gasoline, wring and rinse out until clean, let it dry the re-oil using a plastic bag to keep hands clean.
I will also use gasoline if the filter is EXTREMELY dirty but I try to keep it to a minimum. Gas can degrade the filter & glue used to bond the material together.
273,269
If I keep a machine a long time, I just replace rhe foam element every 5 years or so. Long before they start to fall apart, heck my Honda ATC's the gas tank rusted out from condensation before anything else failed.
Reactions: 906UP
