P500 Air gauge recommendations?
Sledge
Which to buy, where to buy it?
One-hand operation mandatory.
Thanks!
Joe
maddmax
257
231
Clarksdale Ms.
Oops. Meant to post in accessories and mods. Please move there, if you would be so kind.
Thanks.
Joe
i bought a digital air gauge.works great gives 1/2 pound inc. and can use it one handed.Bought at oreillys for bout 5 bucks
Reactions: Sledge
I bought 3 gauges that are supposed to be pretty good. They are $12 each. They read 1-60psi in one pound increments. I don't usually use them for low pressure applications like mowers and atvs.
I compared the three gauges and they all read different. I put them on a 30 psi tire and got readings from 29-32psi. This was just last week because I got fed up with the cheap pencil gauges being 5 pounds off. I do know that dial gauges are supposed to be more accurate and that's what I got but they are still a couple pounds off.
Sent from my iPhone 10s
Reactions: Sledge
rocmar
rocmar
4,741
5,773
4 CORNERS
I use these little tire
gauge from slime
very accurate
20160523 074050
rocmar
rocmar
4,741
5,773
4 CORNERS
How do you confirm their accuracy?
Well I check wat the computer
says my truck tires are...& compare
to wat gauge says.within a few pounds.
rocmar
rocmar
4,741
5,773
4 CORNERS
I feel they are more accurate
than others....I've used
There my preference. ....
I gotcha.
I'm always looking for one that's accurate to a pound or two because I may run 5-8 psi.
Even those $12 gauges differ by a couple pounds.
Sledge
Just bought this one this morning.
Likely an updated version of rocmar's. Impressive construction for $9 (Autozone), all-metal except for the cute little ATV tire armor.
Also picked up an 18"-- 1/2" drive breaker bar and a 19mm deep socket to carry as a lug wrench. $18 for both. Ain't Snap-on, but guaranteed for life, and slips nicely into the tool bag.
Reactions: rocmar
ghost
ghost
993
1,873
BC
I recently bought 2 new gauges cause I wanted more accuracy. This is the 0 to 20. Also got a 0 to 60
http://www.amazon.com/Allstar-ALL44076-Range-Pressure-Gauge/dp/B006K8KICQ/?tag=sxsweb24-20
The 2 new ones are are about 1.5 pounds off at 20psi. Which is "consistent" with the other dial gauges I have (except the cheap one I thru out - it was off by 4). At least the new ones are easier to read.
I guess the important thing is getting consistent readings so you know your tires are even. And you can reset back to a previous setting you liked better - whatever the reading was.
Reactions: Sledge
Sledge
Exactly.
Joe
Reactions: rocmar
rocmar
rocmar
4,741
5,773
4 CORNERS
In place of a gauge use TLAR (that looks abut right). It's always with you and never wears out.
I can agree to this::::
if you know your ride &
are an experienced rider
you can tell....where your at on your tires
rocmar
rocmar
4,741
5,773
4 CORNERS
View attachment 15706 Just bought this one this morning.
Sledge...that one is probably
more accurate than mine...
rocmar
rocmar
4,741
5,773
4 CORNERS
8 out of 10 tire problems out on
a ride....is low pressure & the
bead breaks....
now I'm talking here where
I ride...
I'd rather feel a few more bumps
& not have to deal with it....
10 psi....all corners
with Maxxis Cero's
