All things R/C
62,510
Ok. So I have a ? I've noticed an odd noise in the drivetrain. Sounds like something is bent, no axels that I can tell are bent no marks on them. At slow rpm it will almost stop at the noise. Any ideals ?
I'm guessing the Maxx has a center driveshaft like the XMaxx? Any big jumps? The Traxxas bearings are known for being pretty crappy so it could be a stuck bearing as well.
CMB
CMB
5,108
55,092
Ohio
  2. Talon X LV
Yes it does have the center shaft. No barely off the ground. I noticed it after it kind of barrel rolled in the grass not going very fast at all.
62,510
What replacement bearings would you recommend ?
I've always used Avid but I know the guy who owns the company and have raced with him for years. There are a ton of aftermarket bearing guys now though. I'm not sure if David (Avidracing.com) sells them in kits for the Maxx. He has mostly race-based stuff. I think FastEddy or something like that carries a lot of Monster Truck/Basher bearings from what I've seen on FB and stuff.
62,510
Check the wheel nuts too and the hexes. If they are loose at all or too tight they will bind
62,510
Finally got everything in for the kids SCX10
1610656712181
211,937
Installed? That's one killer paint job! I bet your Angel loves it! Stoped by the hobby shop to pick up a clear body, it was for the Gen 1 Night Crawler, went online and didn't find anything for the Gen 2? The more I think about it, the better I like the Zebra stripe idea, Smitty's Safari! HA!
62,510
FlySky radio is pretty damn good for $69.99. Threw this $17 servo in that had a ton of good reviews on Amazon. $149 Hobbywing ESC/Motor combo. Not bad, and the receivers for the radio are only $20 if we add more cars later.
1610661571075
1610661488584
1610661551057
1610661571075
211,937
62,510
So you got away from the 2.2?
I bought some 2.2's, but to be beneficial I need some 18mm or bigger hex extensions (stock are 6mm). I ordered the hexes before I ordered the tires and they are still in usps purgatory. They might show up one day. Been tuning mine for the 1.9's though
62,510
Current situation...
PXL 20210115 143907915
3D printed this bouncer body/chassis for the SCX24. It was a 13 hour print and it took me another hour or so to remove all the support print and clean it up.
PXL 20210115 115102915
Now I'm trying to figure out how this thing goes together
Todd627
Todd627
57,265
624,734
MI
Fatsquatch
Fatsquatch
Approved Member
121,176
1,010,432
Hidden
I didn't realize there was clean up required to these 3d prints I've been looking at. lol
211,937
No way in Hades I'll ever catch up to your talent level! Or even close. That's cool! How durable will it be?
62,510
Ohhhh yes. Wish I had taken a picture of it next to the pile of support scrap. There was more material in the supports than the actual printed piece. Anything with an overhang needs a support otherwise you end up with a spaghetti monster as there is nothing for it to stick to.
Not mine, but this is usually the outcome if the supports fail or you don't remember to turn on the supports before you slice the .stl file:
1610725821806
