All things R/C
211,939
Added weight to the Night crawler as well, 4 OZ front and 2 OZ rear, these are 1 OZ weights. Would like to figure out how to mount the weight down low?
IMG 4888
IMG 4889
IMG 4888
62,510
I finally got the 3D printed SCX24 chassis together. The guy who designed it was using larger shocks off some other buggy, so I've been just drilling holes and seeing how it pans out, lol. Pretty fun. Printing some high clearance links and a 4 link setup for the front. Got some parts in for the Gatekeeper as well today
1610771560183
1610771577822
1610771931469
1610771951743
62,510
211,939
You friction wizard! HA! I'll bring the beer, what's your address? HA!
Mopower58
Mopower58
Unburdened by what has been!
87,665
752,072
Crystal Springs,Ms.
What loctite to use on Betty screwing into aluminum and brass. Will 222 work which is purple in color and the weakest of the bunch? Will this also work on the beadlocks for the SCX-10?
211,939
You could put one on either side of the axle, just use the tape. You could bend the weights so they would fit more to the concave of the axle housing as well:
I think I've got some sheet lead that could be soldered and would be easy to work with?
62,510
I never use loctite on any R/C screws with the exception of motor mount and clutch bell screws on a nitro buggy. The heads are just too small and will almost always strip. I wouldn't even think about loctite on the little guy.
Mopower58
Mopower58
87,665
752,072
Crystal Springs,Ms.
Thanks for the "real world" info!
211,939
211,939
I had fun. I am definitely the slowest guy but I made up for it by having more fun than they did.
All that counts! Stoner with 33 crashes, I wonder why? Looks like a blast! I was trying to figure out the track lay out and didn't come up with a definitive answer? I know spit about track racing, what happens after a crash?
Fatsquatch
Fatsquatch
Approved Member
121,187
1,010,463
Hidden
Someone just flips the car back over. Racing just keeps on rolling. I’ll try to draw the track layout tonight and post it.
