All things R/C
211,850
If you don't have Traxxas vehicles, you might want to shy away from that one. Traxxas uses a proprietary connector that has the balance lead integrated into the single plug. The one I linked before was a little Venom unit for $50.
Thanks! I kept digging and found your post with several chargers listed, watched some You Tube on the Pro 4 and ordered it a bit ago, this charger will do what the two of mine can't. Pretty simple to set up for different batteries and mHa's. Thanks @Adam490
62,510
Thanks! I kept digging and found your post with several chargers listed, watched some You Tube on the Pro 4 and ordered it a bit ago, this charger will do what the two of mine can't. Pretty simple to set up for different batteries and mHa's. Thanks @Adom490
No problem @Smooty335
62,510
Printed up a shock stand since mine was MIA. Enduro kit should be here tomorrow
PXL 20210127 031851252
Fatsquatch
Fatsquatch
Approved Member
121,154
1,010,267
Hidden
Well hell, no wonder you came in last...
sneaky sum b****es kept flipping the track over.
Right! It was like F-Zero or some of those new Mario Kart tracks. 😂 🤣 Nah, not only did I do a terrible job at the controls of the race car; I also did a terrible job at phone photo controls. Apparently I'm not nearly as young as I once was.
211,850
Don't give up, we can't let those young whipper snappers show us up!
Ridinfool
Ridinfool
36,144
386,049
Western North Carolina
🤣🤣 Clearly.
62,510
I've got to get me a tool kit. These things have some weird metric sizes, there are some sizes between .5.
Buy once cry once; MIP or Hudy tools. Get a 1.5mm, 2.0mm, 2.5mm, 3.0mm, 5.5mm nut driver, 7mm nut driver and that should cover you for pretty much anything. The nut drivers you can get away with cheap stuff but buy MIP or Hudy on the small mm drivers.
This works in a pinch if you've got a harbor freight around. The tips wear pretty quickly but for the $5-$6 you pay for the whole thing it's not bad. This is what I have in my little trail bag with a few spare parts:
PXL 20210128 034301233
