All Thingz UTV Tender Spring Install help
L
lifeisgoodsteve
118
256
Bitterroot Valley, MT
Hi All,
My local dealer is having issues installing the rear tender spring so wonder if there's any documentation or help you can provide that I can share with them?
Thanks,
s
5,427
24,926
Talon X or R? It's a pretty simple project, did they say what kind of problems? If an X, does the kit add crossover rings like the Weller Racing upgrade does?
L
lifeisgoodsteve
118
256
X4
Not sure what their challenge is. They sounded a bit confused. Got in touch w All Thingz UTV so hopefully they'll get on the same page. Just came with the springs.
Reactions: CID
sspeederr
sspeederr
391
661
Just as @CID said tender springs are straight forward without special coil compressor one could do all 4 corners on ground in 2hrs max, I have them down to 45 min but that's with a rack and strut compressor
Reactions: Prntckt
L
lifeisgoodsteve
118
256
Hopefully they're on the right track now. What was the ride height you guys ended up with after install?
I've got the 32" BFG KM3's on the X4LV.
sspeederr
sspeederr
391
661
honestly never measured just installed for customers avg gain i would say about inch to inch and half depending on preload i cant base off mine due to satv 3 in lift
5,427
24,926
That's kinda/sorta your choice, I chose to keep the stock geometry (13") + 1" for my 30" tires which put me at 14". You 'can' crank 'em up for an extra inch or two but I didn't want to do that. If you chose to stay stockish, add 2" for your tires.
5,427
24,926
Thanks. I was targeting stock geometry also, of stock +2" w 32" tires.
The Honda website says the X4 has 12.8" ground clearance + your 2" puts you a 14.8" (duh). Set your preloads to get there. Note that mine wouldn't 'set' hitting the curb into my driveway a few times, I had to take it for a ride to do that. Get a spanner for your shock preload rings (Google), jack the buggy up to unload the springs and tighten, or loosen, as necessary.
These come as a pair, I only used the double ended one (and the R has 2-1/2" shocks so don't order these).
Link
