P1000m5 Another tire question
Chris907
Chris907
Alaska
IMG 1849
Stick these things in mud. They just don't have the torque to do it. And forget about trying reverse. It will just torque up and stall. Love it in almost every other scenario. But once a tire is suctioned in, your pretty much done.
I've been through all sorts of mud. No problem. Maybe you are doing something wrong?
Reactions: JTW
Dude.. that's not right at all!!
Reactions: joeymt33
L
Logan
69
146
Canada
I don't think we are talking about the same kind of mud. This is muskeg and clay. And both the pioneers get in trouble if they get in deep. Both are well maintained. Both experienced drivers. Both same complaint. The gearing for reverse in these is one of hondas biggest screw ups. If someone offered a machine that could seat 5 and not be 30' long, I'd probably switch.
1e2e68846b6e702c32bf2d7e6d4dc712
Thanks for the explanation and pictures. That is quite extreme terrain. I'm sure that's out of the designed purpose. I agree that the gearing is too high for extreme recreational use. However, we also have an un-modified P1000 for work use and it's not given any trouble except for the piss poor dump bed.
There is a gear reduction kit available. I would like one myself one day when funds are available. You should look into it if you haven't.
Reactions: ohanacreek
pct
pct
Lost in the hills
790
1,023
Letart WV
Looks good how do they ride slow and how much do they weight each
boatman22
172
309
Woodlands TX
  3. Other Brand
I did not weigh them but they a much heavier than the stock. Slow ride is not bad on dirt but concrete you know the buggy has mud tires on it. Went last weekend to Mud greek in west Texas and I did not get stuck the entire weekend. There were to mud holes that the buggy stop going forward but I rocked it out in reverse both times. Really liking this setup.
Reactions: pct
pct
pct
Lost in the hills
790
1,023
Letart WV
Thanks for info enjoy it
boatman22
172
309
Woodlands TX
  3. Other Brand
No lift. The right front tire rubbed at a full turn. The plastic stuck out further than the left side. I drilled 3 holes and put push pins to hold it back to the body...no more rubbing.
Reactions: pct
