P1000 Are the wheels the same size?
schmitz504
schmitz504
6
I have a 2019 Pioneer 1000-5 Limited Edition. Are the front and rear wheels the same size? I know the tires are not, just wondered about the rims. Thanks!
A0F79AC7 6CFA 4DFA 9F60 D4ECBF7BAFE7
283,559
No the front rims are 1" narrower than the rear. Also front offset is 30mm and rear offset is 50mm.
I
Ingfam
36
Along this same vain but not entirely on point I have question. Can I run the stock front wheel and tire on the rear as a spare? thanks in advance for the answers.
Reactions: Lady01
StewB
StewB
770
3,564
They say:
The front will work on the rear as a spare. The rear "can" mount on front, but the bigger offset will limit turning range.
And I am soon to test the front as a spare. I bought a 14x7 5.0 - 2.0 offset rim and mounted a 27x9-14 tire to use as a spare.
I have to get to my machine to test it out.
Reactions: Ingfam and Lady01
Hillbillytnt
Hillbillytnt
559
2,053
Ky
Fronts are 6.5”. Rear are 8”. Most aftermarket rims are 7”. That’s why you see so many running spacers.
Reactions: TripleB and Lady01
StewB
StewB
770
3,564
What he said ^^^. The 7" rims will work as a spare without a spacer. I've read that the rear offset is 5 - 3, which makes sense.
The other factor is the bolt pattern: 4/137 for the Pioneer. I've read that 4/136 will work, but who knows.
Yes, I've been reading too much.
Still, I'll go test my spare and report back.
PJon
PJon
800
3,242
Arizona
I changed mine to 14” 5-2 for all corners running System3 350’s 14x28Rx14 tires. One inch spacers on rear and carry one of my old front tire/wheel combos for a spare, though I’ve never needed it.
Reactions: Lady01
I
Ingfam
36
Thanks for all the response. StewB. I hope run into you on the trail some time.
Reactions: Lady01
Y
Yotebuster
12
27
Oregon
So you are running wheel spacer on the rear so the tires track the exact same width? Is rear end narrower than front? Been going to order new tires and wheels for mine all the way around
14x7 5-2 offset. 28-10-14 tires all 4 corners
Reactions: Lady01 and Coeus
PJon
PJon
800
3,242
Arizona
Yes, the wheel spacers brought it back into an equal stance front and rear.
