P700 Arm guards
E
Ehunter
89
262
53
Bend
Are they a must for general trail riding Honda 700-4 Delux. I guess my question should I get them.
sporttrac4x4
sporttrac4x4
1,177
2,083
ILL.
They help a lot but you do have to keep them cleaned out. They help protect your CV boots and your arms so you don't have to work on it as much.
FlipKing
FlipKing
139
298
You can get a set for less than $150. Go price axles. Well worth the peace of mind
Reactions: Russ989
Russ989
Russ989
22,642
147,257
I had them on my 700-4, they helped for sure. I wouldn’t trail ride without them.
Reactions: Mudwing
livefromthetree
livefromthetree
It was a damn good ride. Seriously good.
466
1,309
Mount Vernon Indiana
Post up where yall are getting them and if they were plug and play or needed modding
Reactions: FlipKing
E
Ehunter
89
262
53
Bend
Thanks I will get some ordered asap
Mudwing
Mudwing
36,959
306,672
The Mud holes
I don’t have a arm guards and I probably won’t get them. They hold mud and debris in them. I ride mud, woods, etc. I’m at 1700 miles with only one torn boot early on that was my fault. I forced it over a large branch because I didn’t want to get out and move it so I tore a boot. $15 to fix and never happened again. My brother has them on his 7hundo and he likes them otherwise. If you do get them, watch your front brake lines. You may have to take off the black Honda guard because it pinches the line with aftermarket A arm guards. 😉😎🤎
208,726
I agree!
A
akmarcd
7
5
Palmer, Alaska
I use them and like them however they do collect mud so I had to modify by drilling a massive 2" hole in the bottom and had to cut off the front flange that said "Honda" off the front guards because it rubbed on the caliper guards and caused the brakes to fade in tight turns.
FeelinRecless
FeelinRecless
182
549
They list them up to 2019. Does anyone know if they changed something where they wouldn’t work for a 2020?
Slackjaw
Slackjaw
286
459
Durham NC
I added a set of cheap aluminum guards and I'm glad I did. I'm a woods rider who is more likely to run over brush than to move it.
They already have a few dents from branches and flying rocks. They are loud as hell when a rock bounces off. Scared me half to death first time!
FlipKing
FlipKing
139
298
20200607 180027
