P700 EMP A-Arm Guards
Russ989
Russ989
22,645
147,291
Well, there you have it.
71B4267E 0D4E 4C4E 908E 96449CA824B8
Russ989
Russ989
22,645
147,291
Installed the Honda Oem guards, quick install and easy.
171A5097 CE69 498D 883A C0AC53832F75 FCBB470A 6B4E 49AF A50B 7A699007A27A
Russ989
Russ989
22,645
147,291
They look thin from the pics.
That aren’t super thick by any means but do offer protection, I’ll try to measure the thickness when I get a chance.
Russ989
Russ989
22,645
147,291
Anyone ever tried these? They're supposed to be 1/8 in. And this skid plate is supposed to be 3/16. Price is right on both.
They are cheap enough, my Honda oem guards look to be 1/8th inch. When I do my full skid I’m doing uhmw trail armor.
Russ989
Russ989
22,645
147,291
I just pulled the trigger on the UPI full skid plates and A-Arm guards. I'll let you know how it goes.
What was the damage on that? Those full skids are high.
MKULTRA
Account Closed
Account Self Deleted
84
282
53
IA
I have the upi front & rear a-arm guards on my 2014. They are very tall, stout, thick & fit well. I am very happy with them but there are 2 things you should be aware about them:
1. They hold alot of whatever you are going through (snow, mud,etc). Im sure this is true of all a-arm guards. The upi guards do have large holes in them but they dont release debris to well. But i spose if they allowed stuff to fall out then sticks could get in so its a tradeoff.
2. I had to remove the front stock plastic caliper guards in order for these to work. After I installed the a-arm guards, I noticed that whenever I turned sharp one way or the other, the front brakes would lock up. After some inspection, I noticed the a-arm guard was slightly touching the brake caliper plastic shield, which would then push on the brake line during sharp turning. In my opinion it was not interfering with the line enough lock a brake up, but I removed the stock plastic caliper shield & this solved the problem.
I’m curious to see if these guards do the same on a newer machine then a 2014.
I’m still happy with the purchase and the product though.
Gunslingertom
Gunslingertom
104
171
SW Missouri Ozarks
I'll let you know next week. I'm going to install everything on Monday.
My brother works for a Polaris dealership in Iowa. He says that he has to replace a lot of CV boots because of debris in the a arm guards.
Reactions: MKULTRA and Russ989
MKULTRA
Account Closed
84
282
53
IA
Heres a couple of pics of the UPI the front & rear a-arm guards on my machine in case you were interested.
4C05732D D8F4 4FD4 9697 D33829706295 Front
7B4FA268 2DB6 43E3 B63E 3074996EC92D Rear
Gunslingertom
Gunslingertom
104
171
SW Missouri Ozarks
Got my UPI skid plates and A-arm guards installed today. Pretty straight forward. I did have to drill 2 small holes in the lower rear A-arms, but other than that, as long as you have a good place to work on it, takes maybe 30 minutes. And no interference with any brake parts.
Pics aren't very good, but unless I were to actually pick the machine up, it wasn't happening. I did this at work, where I operate a CAT 950H wheel loader, so I could have picked it up, no problem. LOL!
Rear A-arm guards
Pioneer skid plate 1
Front A-arm guards
Pioneer skid plate 2
Skid plates
Pioneer skid plate 3
Skid plate
Pioneer skid plate 4
A-arm guards are 1/8" water jet cut aluminum and the skid plates are 3/16" plasma cut aluminum. All of it together weighs exactly 30 lbs. Probably a bit heavy, but at least it's on the bottom side.
Russ989
Russ989
22,645
147,291
Rear A-arm guards
Front A-arm guards
Skid plates
Skid plate
Looks good, here are some pics of my front guards, they look to be the same thickness.
C48BDD4E E9CF 4DEA B64F 5FA4D206606D
37B050C1 3484 45BE 957C 0E33EF0C5106
Reactions: Mudwing
CWL23
69
46
Louisiana
Does anyone know where to get a arm guards that I won't have to drill into my a arms?
Reactions: Russ989
Russ989
Russ989
22,645
147,291
Mine are oem Honda, no drilling necessary.
Reactions: Mudwing
