that's it . nice install. the oil cooler is a heater and cooler it heats the oil up during warm up and cools it when its working hard. oil will usually run a few degrees hotter than coolant so when up to temp it a cooler.
guys just remember in the spring you cant block the flow it all of the water that cools the engine. im running a 5/8 heater core and I never hear the cooling fan running while the heat is on but im betting when the 70 deg weather comes I will have to run a buy pass or just unhook it. mine is in the cab on the wall between the two seats so I will probably take it out for the summer.
