ATV Lawn Mower - The RAVEN MPV - ATV? Lawn Mower? Generator?
admin
admin
Your club! I just turn it on!
317
29
Check out this new lawn mower I seen at LOWES today. It is a ATV like lawn mower that is electrically powered. It has a gas engine that turns a generator. It is a full blown generator that pushes 7000-watts of electricity to take power wherever it is needed... Around the house, farm, on the trail... 3 pins and you can remove the deck and take it down the trail!
Youtube - http://youtu.be/O6UtGkZEfrc
Here's the Specs:
  • List Price - $2,999
    46-in Hybrid Riding Lawn Mower
    Creates over 7000-watts of electricity to take power wherever it is needed
    46" quick-release cutting deck detaches in minutes with a simple pull of plug and 3 quick-release pins
    17 MPH top speed for getting around your property faster
    Fewer emissions, less noise, with more usable power than standard riding mowers
    Expandable storage bed to haul tools or equipment
    ATV-style shocks/frame/suspension capable of taking on tough terrain
    Capable of operating up to 12 hours on a single tank of gas
    Completely self-charging technology prevents the need to ever manually charge batteries
    Pulls heavy loads up to 500 lbs
    Series Name N/A
    Engine Displacement (Cu. Centimeters) 420.0
    Engine Brand Raven
    Engine Type Single cylinder
    Cutting Range/Yard Size (Acres) 2-3
    Recommended for Terrain Type Hilly
    Cut Width (Inches) 46.0
    Number of Blades 2.0
    Blade Length (Inches) 23.0
    Blade Engagement Type (PTO) Electric
    Discharge Location Side
    Cut Height Adjustment Yes
    Overall Length (Inches) 80.0
    Overall Width with Deck (Inches) 46.0
    Weight (lbs.) 750.0
    Overall Height (Inches) 50.0
    Frame Type Tubular
    Transmission Type Foot pedal direct drive
    Mower Deck Drive Direct drive
    Towing Capacity (lbs.) 500.0
    Suspension Type Independent
    Fuel Capacity (Gallons) 5.0
    Fuel Gauge Yes
    Oil Filter Type N/A
    Recommended Engine Oil 10W30
    Engine Oil Capacity (oz.) 37.0
    Engine Oil Included Yes
    Battery Type SLA
    Battery Recharge Time (Hours) 0.0
    Crank Battery Charge Time (Hours) 1.0
    Battery Level Indicator Yes
    Front Wheel Size 18-in
    Rear Wheel Size 20-in
    Size of Deck Wheels 5-in
    Number of Deck/Anti-Scalp Wheels 4.0
    Front Axle Cast steel
    Steering Type Deluxe wheel
    Adjustable Steering Wheel Yes
    Turning Radius (Inches) 16.0
    Cruise Control Yes (electrical)
    Maximum Forward Speed (MPH) 17.0
    Maximum Mowing Speed (MPH) 5.0
    Maximum Reverse Speed (MPH) 6.0
    Operator-Controlled Mow-in-Reverse Yes
    Hour Meter Type Meter only
    Ammeter No
    Deck Gauge 12
    Grease Fittings No
    Bagger Capable Yes (3-bin bagger sold separately)
    Mulching Capable Yes (plug sold separately)
    Generator Running Watt Range (Watts) 6500.0
    Generator Starting Watts (Watts) 7100.0
    Generator Run Time at Full Load (Hours) 6.0
    Generator Run Time at 1/2 Load (Hours) 10.0
    Generator Cord Set Included No
    Number of AC Outputs 5
    Number of 12 VDC Car Plug Outputs 1
    Generator Hour Meter Yes
    Storage Bed Yes
    Seat Type High-back
    Adjustable Seat Yes
    Cup Holder Yes
    Headlights LED
    Manufacturer Color/Finish Black and red
    Color/Finish Family Black
    CSA Safety Listing No
    ETL Safety Listing No
    ANSI Safety Listing Yes
    Warranty 3-year limited
855722004009
Mqdefault
A
atv
20
  1. Big Red
Re: ATV Lawn Mower - The RAVEN MPV - ATV? Lawn Mower? Genera
This is what you call a ALL-IN-ONE. ATV, MOWER, POWER anywhere on the trail. Though a good idea for the city folk.... I sure as hell want be buying one.
Can you get it in 4x4? lol
Reactions: ohanacreek
Rinconman
6
hahahha...
This is funny.
lol..
This is a city clicker's ATV.
jwfirebird
jwfirebird
927
1,446
western ny
I think its a good idea, generator never works when you need it because it gums up setting there, if you have one tool that does that and picking up the yard would be nice. but I have 3 acres I mow 46 inches is not going to do, that's what I had at first it 5hrs, also not going to pay that much, should have a utv dump bed and 54inch deck for that price then I would think itd be worth the money for many people that don't trail ride
Backwoods
Backwoods
35,775
362,038
Douglasville ga
I saw one at Lowe's in DOUGLASVILLE kinda neat idea but I wouldn't have one.
