AuxBeam LED bar/Pods Installation Requirements
TOGAvenged7x
6
Aiken SC
Just Use one of these there’s multiple different ones you can choose from
Limited-time deal: Auxbeam 8 Gang Switch Panel BA80 Automatic Dimmable LED Touch Control Panel Box Electronic Relay System Car Touch Switch Box Universal for Truck ATV UTV Boat Marine SUV Caravan -Blue, 2 Years Warranty https://www.amazon.com/dp/B07KZLB74K?tag=sxsweb24-20
That's actually right up the alley that I was looking for.
I am electrical ignorant so excuse the following question because a Google search yielded me two different answers.
If I add another battery and tie them together does that just give me a 12v system will double the amperage or does that effectively make it 24v?
Reactions: TxDoc and Remington
106,135
Nope, give you 12v. One battery is for the rig, the other is for accessories. Go to the club store and get you a true Isolator kit that will hook you up fo sho
Reactions: TxDoc
TxDoc
TxDoc
1,633
5,649
TEXAS 🇨🇱
photos.app.goo.gl
Did you use a pre-made cable that plugged into the back of the switches?
I would like to plug into switches, because my understanding is the switches power off when the key is off, which prevents battery drain.
The other thing is do I need to add another battery? It looks like there is another tray for the battery under the hood.
As Remington stated, these gang switch panels are becoming very popular with the LED lights. I just had more lights than any available switch panel offered.
I have always used my own stranded wires, from reels that I have in the shop for car, truck, trailer, etc, DC needs. In in various gauges and colors.
Same with boxes of coiled solid wire, in for AC wiring from 14 to 6 in various colors. And, reels of standed, too.
My father was a master electrician and electrical contractor for commercial and industrial jobs for over 60 years. I miss him (and my mother) every day more than any words can describe .
But, I never used a supplied harness for lights, and used a fuse and/or relay when necessary.
Do a search for series vs parallel wiring off batteries.
Like this
Sent from my motorola edge plus 2023 using Tapatalk
