I have a 2021 1000-5 and after I put the a arm kit, 3” lift, and wheel spacers from SATV on it made the back tires toe in pretty bad. Anyone else had this issue or know what it might be? Thanks in advance
What @JenElio said. They don’t come preset to all the various setups. The wheels don’t stay straight through it’s compression/rebound so lift it’ll be way off and SATV is only relatively close by themselves.
It ain't that bad @Smitty335 ! It ain't that fun though. Just takes a little patience.
But yeah, that's pretty normal after adding a lift. You'll need to adjust for the suspension change.
And always make sure you roll the machine out down the driveway before checking it out. The suspension needs to settle before checking those measurements. Toe and camber is always wonky right after you set it down on the ground after working on it.
