Can you give me an idea of what you use for back-up lights? If you've got them on your buggy, can you give me an idea of how you installed them and how you switched them, do they come on when you put it in reverse or do you have to flip a switch?
On another note, haven’t seen any pics of your machine in any of your post!
as we like to say...
pics or it didn’t happen
May I kindly ask what that switch is on the bottom right next to your volt meter?I mounted mine high as well and put a switch on them. I hunt out of my rig and didnt want the woods lit up when in reverse at dark (unless I needed to).View attachment 202197View attachment 202198
Great minds think alike. I was getting ready to ask that same question.May I kindly ask what that switch is on the bottom right next to your volt meter?
Wetsounds bluetooth rocker switch (bluetooth receiver).May I kindly ask what that switch is on the bottom right next to your volt meter?
That’s a pricy little bugger. Looks like it’s worth it tho!
It's only a bluetooth receiver/controller. It outputs signal to a microphone jack. I then used an adapter to convert to rca plugs then split them to two amps for a pair of 6.5" component speakers and one 8" sub. You can pause/play, skip tracks or increase/lower the volume with it. Its sounds pretty dang good in my opinion, and can get very loud.That’s a pricy little bugger. Looks like it’s worth it tho!
I couldn’t see if it works for any stereo or just the wet sounds?
