Basket attachment
sgerksinwi
sgerksinwi
203
264
WISCONSIN
My son is coming over to help to build a rear basket.
Our concern is how to attach it.
We were thinking of a split collar.
Our is it the best to bolt it?
All options would be appreciated
Thanks
Thanks
This is how the strong made attaches
Reactions: rocmar
HUCK
HUCK
1,047
2,319
ARIZONA
Hose clamps would be real easy .
If I were fabing one I would probably make my cross pieces on the bottom align with the rack bolts and then drill the cross piece holes and just use a longer bolt to go through both.
rocmar
rocmar
4,741
5,776
4 CORNERS
Don't forget
...LOC TIGHT......
Thanks
Welcome to the club and good luck with your fabrication. Btw, pipe insulation or double stick foam tape is good to put between them so you don't get rubbing squeaks.
rocmar
rocmar
4,741
5,776
4 CORNERS
Bolt it....Dude
with LOC tight
don't use velcro clamps
( mostly used on PoPo,s)
O
oldfortyfive
606
1,371
Illinois
I put a plywood platform on my rack and just used heavy plastic tie wraps to hold it on. Everything then is attached to the plywood. I used the tie wraps so I could remove it easily and everything then comes off with it. Plywood and original tie wraps have survived 5,000 on my trailer this year so far with another 3,000 miles to come in November.
I went the plywood route too. Nobody would use Velcro clamps. Hose clamps is what was suggested.
182,278
Bolts, washers, lock washers and nuts...in six locations right through the flats on the rack. Four of them are in the toolbox.
I used to worry about drilling holes, then realized that I never sell anything. ;)
Reactions: JTW
Yeah, that's what I did with my plywood. And I recommend the plywood too because it is a noise deadener. That's funny, my wife makes fun of me because I don't sell anything.
Reactions: trigger
Lol.. Exactly!!
