Have a 2016 P500. Bought it 6/6/2016. Had to replace battery 2/5/2019 (just shy of 3 years old). Had to replace battery again 6/1/19, and then again 10/31/2020, I have a battery charger / tender that I will hook it up to periodically. I had the machine out and ran it around the yard for about 15-20 minutes about a month ago. Went to charge it today, and meter on NOCO charger showed less than 25%. Meter hadn't moved after 3 hours. So, I thought maybe there's a issue with meter - let's see if it will start. It would not. Hooked NOCO jump box to it, and it fired up and ran fine with plenty of power and headlights were bright. Hooked it back up to charger and still won't take a charge. I've got an appointment with dealer for annual service on Thursday. The only add-on electrical accessory is a KFI Winch.
This continuous battery replacement is getting frustrating and expensive. Any ideas as to the problem? Could the winch be draining it like this just sitting there?
