p5 would only turn over and sputter occasionally when temp was 29 degrees, but later temp was 45 degrees started right up and voltmeter showed normal charging numbers. Any ideas on why p5 would not start?
It was cold ?p5 would only turn over and sputter occasionally when temp was 29 degrees, but later temp was 45 degrees started right up and voltmeter showed normal charging numbers. Any ideas on why p5 would not start?
Battery is going on 5 yrs. Going to check it out. Thanks for the input. Voltage was a little low 11.9 but jumped to 12.5 after it started and I shut it off.How old is the battery?
What is the battery voltage at 29F before starting.
I know this is not the same problem.
My truck would not start at -11F, but would start at 26F.
Had to charge the battery to start at -11F.
The battery was over 3 years old.
Changed the battery and fixed the problem.
Well, that depends on if you think 29F and 45F are cold ... 😆It was cold ?
Lots of shortages are here. Wife went to Meijer and Walmart yesterday. Bread aisle and meat counter below. Thanks, Brandon!Yep just purchased a replacement battery today. Dealer has heard there may be a battery shortage coming. Thanks everyone for your input was very helpful.
Shania?He shut down the pipeline now Europe is dependent on Russia for heating oil so do you think they will really help stop them from invading Ukraine? We are in surious trouble. China is eyeing Twain.
