P500 Battery Issue
A
AM500
29
32
Bayou
So I get home from riding today and I notice a high pitch whine or whistling sound coming from my battery and it was extremely hot. I removed the battery just to be sure that's where the sound was coming from. It's a 2016 and the battery is the original.
Is it a bad battery or could I be having other issues?
Chadmwallis
46
24
I’m not sure about the p500 charging system. There should be some sort of voltage regulator that keeps the charging at a safe level. If it malfunctions it can actually overcharge your battery. Is it possible the whistling is the pressure leaking from the battery? Would explain why it’s so hot. Again I’ve never looked at my charging system on my p500 but it’d be my first thought.
Reactions: happyfred
snakeriver
272
596
Clarkston Wa
I would have to agree
Reactions: AM500
A
AM500
29
32
Bayou
Thanks for the reply.
I'm thinking that it is the pressure leaking. From what I just read, they have what is called a voltage rectifier. Doing more research now.
NTC/TAP Transition Member
11,885
90,615
Yep, bad voltage regular was putting out 18 v and bulged out the battery. If replacing voltage regulator, go OEM from dealer. Cheaper one off internet did not work and the return process was a hassle.
A
AM500
29
32
Bayou
I will give my dealer a call tomorrow. I assume I will need to replace my battery as well?
Reactions: DG Rider
11,885
90,615
I replaced both. It was easier to access the voltage regulator by removing the rear passenger tire and unbolting the battery box. Be careful with the box bolts cause the keeper nuts can be pushed out of place.
Reactions: AM500 and Wallace
A
AM500
29
32
Bayou
I should have mentioned that a couple of nights ago the lights where dimming and flickering also.
Reactions: Mudder
A
AM500
29
32
Bayou
Ok. Had the exact same thing happen again today.
Anyone have any ideas?
11,885
90,615
What is the voltage output?. After the bad VR and battery, something like this on the dash gives me piece of mind.
4EE6C743 6E0C 4847 A77E C50B9299648F
5,759
26,450
Did you already change both the rectifier and battery? Next step - check the output voltage like Mudder suggested - a VM across the battery when running if you don't have one permanently mounted. They're pretty cheap and it's worth knowing your battery condition.
I added this before my first ride (it helped that it was mid winter so I couldn't ride anyway).
I v2gT84s L
Reactions: AM500
A
AM500
29
32
Bayou
I'll check the voltage when I get home from work tomorrow.
Reactions: CID
