P1000 Battery Tender Dash Plug
Jamesgang
Jamesgang
148
297
Kitzmiller, Maryland
Anyone using one of these. I like the idea so going to give it a try. Not going to use the NOCO Genius charger. already have battery tenders with the SAE Connection. So going to make an adapter cable.
Plug s l1600 Plug 2 ended s l1600 Plug one ended s l1600
BWAF
BWAF
I get paid to pass gas
8,864
42,478
Carthage MO
Neohio
Neohio
Beast of the East
17,834
86,024
Painesville Ohio
I use the same plug as Ohanacreek.
I have mine mounted on the exterior right above the hood. I throw the entire charger on the hood and plug it in. Helps me to remember to remove it before driving off.
Farmer
Farmer
2,973
17,158
Southern MO
I like the idea but my stock 3 year old battery doesn't go dead. It sits up to a month or so sometimes. Do you guys have some draws on your systems or do they just sit much longer?
Reactions: Jamesgang and BWAF
Jamesgang
Jamesgang
148
297
At the end of deer season mine may set all winter if it's cold and no snow. I only use it in the winter to plow with. so no snow it sets. I'm sure I have draw on it with my stereo, winch and second battery. I would assume bone stock would have some draw just because of all the elec. they have now a days.
Reactions: Farmer and BWAF
gullyjumper
gullyjumper
950
2,413
cookeville tn
On mine I just have the end sticking out at tha top of the hood and connect it there.
Mines in the dash so I loop the charger through the drivers door and i remember to unplug it before I drive off. Also lets me plug in other stuff if I want. I have one of those 150watt defrosters aimed on my windshield that is not permanently mounted that I put a 2Way SAE plug on.
Deluxe700
Deluxe700
856
1,101
Central Arkansas
My SAE connector is on the dash for my batt tender..just easy..
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
Good idea. I think I'm going to do the same thing. Then I can plug in my sprayer and other such items!
BVerhulst
BVerhulst
48
Colorado
Yup, I put an SAE plug on the dash for the battery tender, too; mine is wired directly to the primary battery. When I plow snow in the winter (based on experience with my Foreman 500), I drain the battery hard with all the winch operation, but don't run the motor long enough or high enough RPM's to replenish voltage. Battery tenders are worth their salt for keeping your battery alive and well. But I also added an aux battery with isolator, per what I've read about low-voltage shifting problems in the 1000-5. Once the primary battery is fully charged, the isolated allows overflow to the aux battery, keeping both healthy.
OnTheJob
OnTheJob
426
925
Bristol, NY
I love my battery tender for all the same reasons. This was a very simple plug and play set up for less than $70. She is fully charged every morning no matter how cold it is.
IMG 51441
IMG 5165
Reactions: O2bsmitty
RedFred1
RedFred1
301
619
North Carolina
Dude! That is a very clean set up... I am totally stealing it!
Nice!
FredD
