Multi Battery terminal
ncred02
ncred02
1,031
1,769
Raleigh NC
Anyone know what the heck causes this? I've researched and they say a constant draw. I have nothing, that I added, that draws nonstop.
Terminal
sporttrac4x4
sporttrac4x4
1,177
2,082
ILL.
Corrosion on the terminals is due to hydrogen gas being released from the acid in the battery. It mixes with other things in the atmosphere under the hood and produces the corrosion you see on the terminals. Generally, if the corrosion is occurring on the negative terminal, your system is probably undercharging. Clean it with WD-40 and it should be good
What vehicle is that in. I have a constant draw and no corrosion.
ncred02
ncred02
1,031
1,769
Raleigh NC
2015 F250 6.2L Gasser.
I ended up going to my local auto parts store and the ran a test and said the battery if fine. So I cleaned the crap outta it and sprayed it with CRC battery terminal protectant.
I also researched the Red tops and from what I gather they are a bit over rated.
Reactions: Montecresto
Gator
Gator
The Most Unknown Member
2,475
10,396
Louisiana
You did the right thing. Make sure it is good and tight.
If you had let it continue it would eat up the terminal clamp.
Reactions: JTW
