Battery Upgrades ANY one???
T
Tackle83
Hey,
was just wondering if anyone has found a drop in replacement battery. The alternator is overkill for the size battery that comes stock with the pioneer.
I know i can build and relocate a second battery but a drop in replacement would be nice.
66,867
I thought about buying a optima and enlarging the box or relocating the battery. But I have not.
Just a item on my list right now.
I seen someone did add a second battery.
I may wait till a battery goes dead in one of my other toys. Then I'll give it the OEM battery and the Pioneer will get a new upgrade.
Under the driver seat needs a skid plate and put a Optima. I worry about sticks I've already had one try to take out the gas tank.
T
Tackle83
yea im going to install a larger battery under the hood. i was hoping that there would be an easy drop in
T
Tackle83
looks like this would be a drop in. it is twice the Ah than the stock slightly higher amps and more cca. Thought
Specifications:
High Performance
Maintenance Free
Voltage: 12 volts
Capacity: 12 Amp*hours
CCA:240
Dimensions: 6" x 3.43" x 5.75"
Weight: 8.6 lbs
Polarity:
Amps: 1.4 amps
Part number: YTX14HBS
Fits Honda TRX500FE, FM, TM Trax Foreman 2005-2011
T
Tackle83
In case anyone is looking i did find this battery at advance auto parts.
MagnaPower 12-Volt Sealed AGM Premium Powersport Battery, 310 CCA
Acid Included: Yes
Amp Hours: 17.5 h
Battery Type: AGM
Battery Usage: Power Sport
Cell Electrochemical Type: Acid
Cold Cranking Amps: 310
Deep Cycle/Starting: Starting
Height: 6.125 in
Length: 6.875 in
Maintenance Free: Yes
Package Quantity: 1
Terminal Type: Box
Voltage: 12 v
Weight: 15.5 lbs
Width: 3.4375 in
It is priced at 104.49 with a 10.00 core charge. If you order it online and use promo code trt41 you will get 40.00 off. You can order online and pick up in the store.
I can order 3 Optimas per year for $150-180 each, if anyone wants one I can bring it to the group ride, (the company I work for is the parent company of Optima) I am about to order 2 for myself.
Group 34 55ah Blue or Yellow are $150
Group 31 75ah Blue or Yellow are $180
bigc
bigc
432
127
you must work for johnson controls ohana ?
bigc
bigc
432
127
only about 4 battery manufactures left in the world
Yeah JCI has around 97-98% of US and 75% worldwide automotive and hybrid, at last count.
