Mine is already adjusted as far as it can go, and still rattles. I'm going to try duct tape first, but then maybe a piece of fuel hose around the catch bar..
Maybe try adjusting the latch the other way. Mine would adjust far enough that my bed wouldn’t latch so I adjusted it to where a had to put a little umph to get the bed to latch and now it doesn’t rattle at all.
I'll look again tonight, but both sides are adjusted as far as they can go.. I was thinking about taking them off & grinding the hole a bit further. Hell... maybe I'm lookin at it backwards. I'll check.
Adjusting the latches on mine solved the problem, but if that didn’t work these things were the next thing I was going to try. I was going to stick them towards the front of the bed where it rests against the frame.
