P1000 Best bead lock
Z
zin01
174
235
Royse City
So I’ve been searching as much as I can but I can’t seem to find the answer. What is the best bead lock wheel? I’ve seen some that range from $80 each to over $400 each. I’m wanting to do 14x7 all the way around and wanting to run 28X10 outback max tires I run mostly mud down here in Texas but when my family and I get a chance we want to hit up Moab and other places. I know the tires may not be very good for Moab but I’m focusing on the wheels or rims right now. I know they all look different and I can pick ones I like I just want to know if some are stronger or the bead is better or what the differences are. I don’t want to say money is no object but if some are better then other but a little more expensive I will probably go that way. I just want to put good stuff on my machine that I don’t have to worry about so we can have a fun trip. I know it’s a long post but do appreciate all your advice. Oh also where would you guys suggest buying the wheels from. Thanks
Tim
Reactions: BWAF
I have the ITP Severe Duty Dual Beadlocks but had I not gotten the deal I got I would’ve gotten the HD STI from RMATV for about $90 each they’ve held up well for others who are tougher on their machines.
9b0009a055dcb587cb65570f7b47e2f2
Reactions: zin01
BWAF
BWAF
I get paid to pass gas
8,857
42,437
Carthage MO
Tim
I put sti hd9 on mine they have lifetime warranty 5/16 bolts .394 thick ring seem to be pretty heavy duty same bolt pattern as can-am x3 so was on national back or for 3 weeks , been out once on them . My only issue is I put truck tires on them so beads are thicker and I had to put spacers in between ring and wheel .Going to make full ring spacer some time .$540 for set 6d8acb83db7087686b21522049728c46219a1bac5d2f6d11c1c336b24964a93d05dc3c364c55339055c1913b02cf9d0267b06f697b110b443fb1687bb3005beb49c2b5114487d5cb5d884d4f6e62b6c3
BWAF
BWAF
8,857
42,437
Carthage MO
Bought at Pure off-road. Com
I put sti hd9 on mine they have lifetime warranty 5/16 bolts .394 thick ring seem to be pretty heavy duty same bolt pattern as can-am x3 so was on national back or for 3 weeks , been out once on them . My only issue is I put truck tires on them so beads are thicker and I had to put spacers in between ring and wheel .Going to make full ring spacer some time .$540 for set View attachment 74474View attachment 74475View attachment 74476View attachment 74477View attachment 74478
I really like those
Reactions: BWAF
Z
zin01
174
235
Royse City
I was looking at the STI HD9’s they have some that look pretty good. I like those ones you have.
Reactions: BWAF
BWAF
BWAF
8,857
42,437
Carthage MO
They took some good hits today
Reactions: zin01
Ragnar406
Ragnar406
The Great Bald One
4,446
17,020
Bella Vista, AR
I have the same wheels, they have worked good for me so far. You can also purchase different color rings for the wheels if you want to for around $25-30. I have some battle scars on them already but so far all are on the rings which could be replaced if I wanted down the road.
Like any other beadlock there is a little matiance involved
Reactions: BWAF
Sckottty
Sckottty
35
Abilene TX
discount tire now sells method racing 406 beadlocker 12” and 14”
Reactions: BWAF
